Exhaust/ True Duels ?
Old Jun 22, 2007 | 07:05 AM
mack's Avatar
Default Exhaust/ True Duels ?
Currently have Pacesetter 1 7/8 primaries with 3" collectors, 3" ORY and 3" Magnaflow Cat back with no cat. Would going to a 3" X-pipe true duel set-up help me and if so, how much Tq and HP would I pick up?
Current best 12.98 at 106.34
Old Jun 22, 2007 | 07:19 AM
LT1MAN's Avatar
makes a good bit more, well worth the money. someone will chime in with some numbers im sure.
Old Jun 22, 2007 | 07:28 AM
InsaneAuto86's Avatar
I am about to do the same thing. It's also cheaper than buying an ORY and cat-back.
Old Jun 22, 2007 | 09:17 AM
mack's Avatar
My current set-up is only a year and half old. I asked about true duels then, but the local shops all said it wouldn't be worth it. From what reading now on the forums, this seems to be the prefered way to go. What mufflers are the best to use w a true duel set up?
Old Jun 22, 2007 | 09:37 AM
mack's Avatar
I see your from the tri state area. Ever go to Rt 13 Drag Way?
Old Jun 22, 2007 | 09:50 AM
2quik6's Avatar
I had a shop do TD over the axle and I supplied the cats and mufflers and it ran me about $650.... A year later I redid them myself with mandrel bent universal kit and it cost me about $400 in tubing and 2 days of my time. Well worth it though.
Old Jun 22, 2007 | 09:54 AM
DroppedM6Z's Avatar
Pacesetter makes a 1 7/8's Primary for LT1 LT's?
Old Jun 22, 2007 | 10:59 AM
mack's Avatar
Sorry, my mistake. 1 3/4.
Old Jun 22, 2007 | 11:02 AM
mack's Avatar
Where did you get the kit?
Old Jun 22, 2007 | 11:27 AM
ABA383's Avatar
If you don't mind making a 2 hour drive I could hook you up with a great shop that does incredible true duals...Do a search of my screen name and 3" stainless true duals and you'll see some nice stuff...The shop is in Finksburg, MD...
--Alan
Old Jun 22, 2007 | 11:41 AM
mack's Avatar
--Alan
Would you be refering to Tyson?
Old Jun 22, 2007 | 09:56 PM
2quik6's Avatar
I used a Jegs 3" universal X-pipe kit and a Jegs aluminized steel 2.5" universal mandrel bent kit.
It wasn't a direct bolt in by any means, but all I used was a cut off saw, wire feed welder, and a tube expander with an impact wrench.
Here's some pics in and out of car with 2 different muffler configs..one is straight thru Dynatechs the other is with Hooker aerochambers for a quiter sound. They connect just in front of the axle using V-band clamps so I can change them fairly easily.
Old Jun 23, 2007 | 06:49 AM
ABA383's Avatar
Yes...
--Alan
