Low mount alt, custom PS!!!!!!!!
Old Jun 27, 2007 | 08:13 PM
LALT1's Avatar
Default Low mount alt, custom PS!!!!!!!!
Well after going with the low mount alt. and driving my car around a ton on the street still, and now deciding to run big wheels on the street again it was a must to have power steering. After several different ideas finally designed one that works great and did not have to lose my alt bracket!!! Very happy with how well it tucked in place. here is a few pics of the set up.
Not even noticeable under the CAI!!!
Old Jun 27, 2007 | 09:01 PM
Gun5's Avatar
uhh yep gonna have to post a how to
Old Jun 27, 2007 | 09:03 PM
infinitebird's Avatar
your engine bay is sick man, saw your car at G11. very nice.
Old Jun 27, 2007 | 09:04 PM
LALT1's Avatar
Thanks man, Actually will be selling these kits, we fabricated up the bracket and what not for this application.
Old Jun 27, 2007 | 09:37 PM
foggedz's Avatar
So how many inchs of surface area on the belt is there making contact with the crank pulley/ dampner?
Old Jun 27, 2007 | 09:40 PM
LALT1's Avatar
I will get a exact measurement on that, I can say that from 1000-7000 rpms it is doing just fine.
Old Jun 27, 2007 | 11:13 PM
thesoundandthefury's Avatar
I wish I would've know you were going to do this, because I could've sold you this:
It's got a sliding mechanism for the "claw" so that you have some adjustability for lining the P/S pulley up with the other pullies. The polished stainless link bar uses one of the water pump bolts for anchorage and can be tightened/loosened to act as a belt tensioner.
Old Mar 14, 2009 | 09:24 PM
Turnin20s's Avatar
bringing it back from the dead. How hard was it to fabb up a bracket for this? I'm going to autozome tomorrow to try to figure something out and build my own, but if someone can help me out I'd really appreciate it.
Thanks in advance
Old Mar 14, 2009 | 09:41 PM
MTBSully's Avatar
also like to know. All I want is power steering. I don't need AC, but i really want to relocate the alternator and still keep power steering
Old Mar 16, 2009 | 01:34 AM
Turnin20s's Avatar
Well later in the week I plan on going to the junkyard and getting a power steering pump and starting on a bracket. If it turns out I may make a few of them up and try to sell them. The only problem would be the low mount alternator with an idler pulley fabbed on. I planned on ordering a madman bracket, but for $165 I'll work on making my own.
I'd ask for a template of a relocation bracket so I can make my own, but I don't want to step on any toes and **** off the guys making them and selling them. But it shouldn't be that hard to figure out and make myself.
Either that or I'm going to hack up my stock mount and keep the stock PS pump, but I like the regal pump idea alot better. The only thing I'm really worried about is the belt slipping or being thrown like mentioned above
Old Mar 16, 2009 | 01:41 AM
litch2004's Avatar
well it doesnt move my power steering over there but i relocated my alt to where my a/c used to go. I used the factory AB and did some cutting and fab work on it my self.
Old Mar 16, 2009 | 01:42 AM
litch2004's Avatar
i have another picture of how my top bolt it mounted. So if you need to see that i will post that up tomorrow as well
Old Mar 16, 2009 | 01:53 AM
Turnin20s's Avatar
^^^Yup I have looked at your pics on camaroz28 I think. I have all of the pics saved on my laptop LOL
Looks good, this is my backup plan if the first idea doesn't work out
Old Mar 16, 2009 | 06:01 AM
litch2004's Avatar
yea thats where i got my idea as well. I changed it up a little bit from his. I just did mine last week. It took me probably about 4-5 hours cutting it all and test fitting it to make sure it would all work. I like it though it fits really close and cleans up the engine bay.
Old Mar 17, 2009 | 11:06 AM
Turnin20s's Avatar
I decided to go this route on mine too just because its going to be cheap and I'm broke right now LOL
Post up the pics of the top bolt if you don't mind
Looks good, hopefully mine will turn out that good
Old Mar 17, 2009 | 11:34 AM
litch2004's Avatar
Okay. I will post them when I get off around five.
Old Mar 17, 2009 | 12:36 PM
Turnin20s's Avatar
Nice, thanks man. I might have mine to that point by then
Old Mar 17, 2009 | 12:49 PM
litch2004's Avatar
One advice I can give is the top ear that u cut off try to cut it through the thick part. I used that top piece to make a braket for the top bolt. I did not bolt the back of the alt to the block like on the pics that yoy have due to limited space due to the stock k-member.
Old Mar 17, 2009 | 07:54 PM
litch2004's Avatar
Old Mar 17, 2009 | 07:55 PM
litch2004's Avatar
good luck on doing yours. if you use piggyback style underdrive pullies as well then your belt should be a 54" at least it was for mine.
