Very dissapointed!
Old Jun 29, 2007 | 03:10 PM
Lt1junkie's Avatar
Default Very dissapointed!
Mocked up my X-pipe kit and duel flowmasters dumped before the axles.... Ran everything tight to the floorboard all the way back and turned the dumps at a 45 towards the bottom of the tires before the axles.... Went to lower it down and the damn flowmasters hit the ground!!! didn't take into account the 2 inchs i lowered the car. So now i am trying to sell the mufflers and go with a diff setup.. Anyone got any ideas.. Bullets off the headers dumped? single chambers dumped?
Old Jun 29, 2007 | 03:43 PM
Formula350's Avatar
Don't dump. Run the duals back and have 2 bullets in the back.
Old Jun 29, 2007 | 03:49 PM
Puck's Avatar
Depends on the diameter of his exhaust. 3" pipe is very difficult, if not impossible, for most people to run all the way back.
Old Jun 29, 2007 | 03:50 PM
the_merv's Avatar
Veteran: Air Force
Might have to run a Y-Pipe..
I am goin to have to run the 3" Y-ed into a 4" back, then reduced into a 3" over the Axle into something..
Old Jun 29, 2007 | 04:08 PM
Formula350's Avatar
Pointless to have the 4", unless you're using it for a sound chamber. You can only flow as much as the smallest pipe (3") allows. 6 miles of 4" wont help if it only has a 3" opening. Unless you plan to bring physics into play and make some sort of a vortex to help bring the exhaust along lol Or 4" over the axle so when bent, it's still at least 3-1/2"
Plus, I thought for true duals on a SBC (under X amount of HP of course) that 2-1/2" is all that's needed. We need SOME back pressure right?
Old Jun 29, 2007 | 05:34 PM
dhdenney's Avatar
I have my true duals in 3" pipe with the Moroso mufflers exiting at the rear end with no dumps.
Old Jun 29, 2007 | 05:51 PM
hyperzone's Avatar
I have LT's to an X-setup with bullets dumped with the tips pointed at the tires like your saying. Its all 3"... In this picture I still had stock SS springs and shocks in the front. The back is a tad higher (changed the setup for the stereo weight). It works for me... especially since I got new suspension stuff in the front now.
Old Jun 29, 2007 | 06:35 PM
speed_demon24's Avatar
Pics in here, 3" from collector to exhaust tip and I'm lowered with strano springs, 1.2-1.3". I'm running moroso spiral flow mufflers...
http://s86.photobucket.com/albums/k1...n24/?start=all
Old Jun 29, 2007 | 07:47 PM
DroppedM6Z's Avatar
i'm on 2" drop and realy wanted to go true duals because i'm @ the point where my 3" is @ max flow with the hp the motor makes. I am going to a Mufflex 4" mandrel bent set-up with a 30- series top ten race muffler. Ground pounding muscle car sound. I LOVE the sound the 2 chamber flows make with 4" pipe(Old style NOT Delta Flow).
I'd find some bullets or sweet thunders.
Old Jun 29, 2007 | 08:00 PM
the_merv's Avatar
Veteran: Air Force
I beg to differ on that one..
Read this, this can help alot of us out..This is from a Guy named Patrick G, he does alot of research. He just got a Heads/Cam LS1 with Stock Bottom to put 500's at the Wheels with this Exhaust. This guy does alot of research, also the one that recommended my Cam.
Exhaust selection:
To make big power with a street motor, you need an exhaust that sucks...literally (David Vizard quote). When running a cam with lots of overlap, backpressure is not your friend. But when building a daily driven street car, too free flowing of an exhaust often means too loud. Not in my case.
You want the best headers you can find. For an LS1 F-body, it would be QTPs or Kooks in 1 3/4" size. For a Vette, the LG Pro Long tubes reign supreme. A high velocity merge collector on the header collector is typically worth some nice gains in the mid-range and is known to squeak out a few extra ponies up high as well.
Merging the twin pipes coming off the headers is a critical item for power and sound quality. Vettes have it easy because an x-pipe easily fits and the sound quality is awesome. F-bodies are handicapped because of space constraints. For 500 rwhp, you want to run dual 3" pipes after the headers and you'll want them to merge into a 4" intermediate pipe. Anything smaller will run the risk of flow loss. Most y-pipes on the market slam the 2 pipes together like this:
When the pipes meet at close to a 90 angle, the flow is going to be lower and the sound is going to rasp and drone at 2000-2300 rpm. By using a Flowmaster merge collector or better, your sound quality will improve since the gasses meet side by side as opposed to ramming into each other. Here are a few pics of my exhaust.
Notice the dual 3" pipes merging into a 4" intermediate pipe, then a 4" cutout. After the cutout, the pipe is reduced to a 3" SLP dual dual catback. Compared to open headers with 20" extensions, my motor lost 1 hp with this y-pipe, but gained 10 rwtq in the 2500-4000 rpm range. From a sound standpoint, the rasp/drone is gone with the better y-merge collector. The difference between running with an open cutout and closed exhaust through the tail pipes is 9.5 rwhp. Not bad at all.
Old Jun 29, 2007 | 08:16 PM
DroppedM6Z's Avatar
or just 4" all the way OTA with no HP loss.
Old Jun 29, 2007 | 08:22 PM
dhdenney's Avatar
All the shops around here can't bend 4". How is everyone getting 4"? Am I just in a deficit area?
Old Jun 29, 2007 | 10:27 PM
the_merv's Avatar
Veteran: Air Force
Tomorrow I am goin to get some 3" and try to locate a 16" section of 4", and make that Y-Pipe. I am going to have to bring it in tighter at the Y area cause of the Torque Arm that I have.
Old Jun 29, 2007 | 11:25 PM
96silverram's Avatar
I like the oval drivers side section of 3" for ground clearance, that exhaust is something most shop could not even come close to replicating. Nice....
Old Jun 30, 2007 | 06:59 AM
the_merv's Avatar
Veteran: Air Force
That is a nice lookin setup, hopefully I can get some gains out of it.
Old Jun 30, 2007 | 10:08 AM
dhdenney's Avatar
One thing I have noticed about exhaust is you bout have to have all your suspension and chassis done cuz one change and the exhaust is in the way.
Old Jun 30, 2007 | 10:37 AM
DroppedM6Z's Avatar
Mufflex sells 4" kit's and i am getting some of mine from Semi Truck parts stores.
Old Jun 30, 2007 | 11:14 AM
MM98's Avatar
Another vote for the 4" set-up... Here's a pic of mine when it had a 4" one chamber flowmaster... It now has a spintech super stock race muffler, love it...
Old Jun 30, 2007 | 12:25 PM
dhdenney's Avatar
^^^ I had a similar setup to that until I went to true duals. I bought a 4" Borla and found out no one could bend 4" pipe. So I put a reducer on it and run 3" and stuck out on the driver side like that. I'm saving the 4" Borla for the turbo LS1.
Old Jun 30, 2007 | 02:16 PM
camar0corey's Avatar
I'm just not happy when I see how much a 4" catback costs. That info on the ypipe is interesting though......
I hear it about the chassis/suspension. Every time I asked a shop about true duals they cringed when seeing the spohn suspension parts and slp subframe connectors. I finally gave up on the TD idea.
