Throttle bodys........ What are you using?
Old Jul 6, 2007 | 09:39 PM
  #41
cruzin94's Avatar
where do u find as&m throttel boddies
Old Jul 6, 2007 | 10:53 PM
  #42
dhdenney's Avatar
Directly through Arizona Speed & Marine.
Old Jul 7, 2007 | 02:26 AM
  #43
KWIK WS6's Avatar
got mine through Combnation Motor Sports a couple of years ago, But I dont think they are around anymore.
Old Jul 7, 2007 | 08:15 AM
  #44
ZEX-Z's Avatar
I just noticed there are two part numbers in Summit online for the 58MM Holley throttle bodys. One is priced differently at 349.95 part # HLY-112-505 and the other is 399.95 part # HLY-112-509. I am thinking the cheaper is a 1993 model but what is the difference between the 1993 throttle bodys and the 1994-1997 other than OBD2 generic and OBD 2. Whats the difference between the throttlebodys?
Old Jul 7, 2007 | 05:37 PM
  #45
2000 cam'n SS's Avatar
The ninty threes had 4l60 transminssions witch required a detent cable hook up to control shifts....94 and later models came with the 4l60E witch im sure you know is the electronic version with no detent cable hook up on the throttle body being neccessary.
Old Jul 7, 2007 | 09:10 PM
  #46
dhdenney's Avatar
$50 for a tit on the throttle blade? I have run 700r4 and 4l60e with my BBK. That's the only difference, a tab on the blade for the TV cable to snap to. There has to be something else?
Old Jul 8, 2007 | 12:34 PM
  #47
ZEX-Z's Avatar
We need to do a little more research on these two. 50 Dollar difference for the Holley 1993 model 58MM and the 94-97 58mm? Some thing is wrong. I will get on the phone with holley tommorrow and find out.
Old Jul 8, 2007 | 01:20 PM
  #48
TXTA's Avatar
I only paid like 249.99 for the Summit Throttle Body and that was only like a month ago, maybe month and a half
Old Jul 8, 2007 | 01:41 PM
  #49
James Montigny's Avatar
I believe '93s also have different IAC provisions. (threaded instead of bolted)
Old Jul 11, 2007 | 01:40 PM
  #50
Just trying to help you out....No since in you being a dousche bag
Old Jul 11, 2007 | 02:56 PM
  #51
92LT1RS's Avatar
Old Jul 11, 2007 | 03:37 PM
  #52
Vicious95Z28's Avatar
I have a 58mm TPIS throttle body and I LOVE IT!
Old Jul 11, 2007 | 03:50 PM
  #53
phantomLT1's Avatar
Default Roger Red96TA
58mm Arizona Marine intake best out there
Old Jul 12, 2007 | 06:53 AM
  #54
SSweet97's Avatar
BBK 52mm
Old Jul 12, 2007 | 10:33 AM
  #55
The93z's Avatar
I also have a 58mm BBK, and my idle is always messed up. Do you reccmened me cleaning out the IAC or what?
Old Jul 12, 2007 | 10:43 AM
  #56
dhdenney's Avatar
I would be mad if I paid $50 for threaded holes!
Old Jul 12, 2007 | 10:48 AM
  #57
streetwarrior96's Avatar
Holley 52 mm with no probs
Old Jul 12, 2007 | 11:10 AM
  #58
TWS's Avatar
TWS
ASM 58mm
My 396 def. needs it.
Old Jul 12, 2007 | 02:34 PM
  #59
Speed Density's Avatar
hashtagBMW
Accufab 90mm
Tony.
Old Jul 12, 2007 | 03:07 PM
  #60
NJLT1SS's Avatar
AS&M 58 MM in front of my ported/welded/epoxied LT4 intake. I also have an AS&M Monoblade waiting to go on with new intake.
Nick
