LT1 lap top tunners?????
A laptop tuner, requires, well a laptop! Which is a portable PC (IBM Compatible if you want to get nostalgic), which has software and a cable that connects to the data port on your car. The same port you scan it for Check Engine/Service Engine Soon codes.
Software tuners, which run on laptops, are extremely flexible. Your car is OBD1, IIRC. I would recommend TunerCat and, of course, a laptop. They allow you to make changes to your PCM, which is tuning your car.
A scanner is a different animal altogether. It reads codes, and normally can reset them. The better ones can also do data logging for you, a very useful function.
If you go this route, you need both a tuner (to make changes) and a scanner/data logger (to see how the changes affect the performance of your car).
For example, in my OBD2 car, I use LT1Edit to make the changes, and AutoTap to log the output so I can analyze the effects.
Auto tap is probably the best for data logging. I have tried many other and they don't have all the functionality (especially the free ones) for reading parameters such as knock (very frustrating). Tunercat is no longer available free it is sold by JET and these programs (Lt1 edit) only allow you to tune your own vehicle they do not come with a tune. That is what PCM4Less and MadZ28 do is sell you the correct tune for your setup.
The tuning programs come with a custom connector that alows you to read and write to the PCM which you cannot do with just a scanner.
Also the best datalogging program for obd1 is datamaster (sold by TTS systems).
