gears and rear
Old Jul 6, 2007 | 01:04 AM
Pntbll309's Avatar
Default gears and rear
When putting 3.73's into an auto LT1 do you need to change the carrier? Or will the stock one work?
Thanks
Old Jul 6, 2007 | 01:09 AM
infinitebird's Avatar
If the original gears were 2.73 then no it will not, if they were 3.xx then yes.
Old Jul 6, 2007 | 07:55 AM
imnotplutonium's Avatar
you can get 3.73's for a 2 series carrier though. I have heard they are better, I have heard they are worse.
Old Jul 6, 2007 | 08:20 AM
the_merv's Avatar
Veteran: Air Force
What gears were in it originally?
Old Jul 6, 2007 | 08:38 AM
Pntbll309's Avatar
Stock 2.73's.
Old Jul 6, 2007 | 09:34 AM
Razor_Blade's Avatar
Originally Posted by Pntbll309
Stock 2.73's.
Just make sure that whoever you order the gears from, knows that you have a 2 series carrier.
Old Jul 6, 2007 | 10:27 AM
the_merv's Avatar
Veteran: Air Force
^^ Exactly..that was the info I was goin to give him, reason for the question..
Old Jul 6, 2007 | 10:46 AM
SincalT/A's Avatar
i will recommend changing the carrier.there is a good reason gm changed carriers.its not cause they wanted them to be weaker.
Old Jul 6, 2007 | 01:01 PM
Pntbll309's Avatar
Im looking into getting either Richmond or Motive gears. So I'll check and see if they do them for a 2 series carrier. Thanks guys for the quick responses!
http://store.summitracing.com/partde...5&autoview=sku
That looks to be the one.Can anybody confirm this?
thx
Old Jul 6, 2007 | 01:28 PM
koolaid_kid's Avatar
Yes. There are are 3 ways to skin this cat:
1) Change out the differential (yucchhh)
2) Put a 3 series gear with a spacer (bad idea, weaker and difficult to dial in)
3) Get a gear designed for a 2 series carrier, also called a thick gear (best idea)
#3 is what you have selected, and that is what I have run for the last 7 years with absolutely no issues.
My only caution is: You will enjoy the heck out of it, watch out for the police.
Old Jul 6, 2007 | 02:35 PM
Pntbll309's Avatar
I'm sure I will these stockers are killing me. I'm getting tired of running low 15's at this altitude.
Old Jul 6, 2007 | 03:03 PM
yea some 3.73's for my 2 series are prolly going to be next, as soon as I get me a new DD
Old Jul 6, 2007 | 04:29 PM
Pntbll309's Avatar
My DD is a 600gsxr or an F150 so I'm to do them
Old Jul 6, 2007 | 05:31 PM
Police! There Are Some Upcoming Offenders!.
Old Jul 6, 2007 | 08:13 PM
Pntbll309's Avatar
Oh hell I've had my share of tickets...I just want a 1/4 mile car that will kick my brothers lightning's ***...His best is like a 13.8 @4600' alt.
My car turned a 15.4 at 5200' with nothing done to it but a hyper tech...Does that sound about right?
Old Jul 6, 2007 | 11:34 PM
cruzin94's Avatar
do other make this "thick gear'' for the 2 series besides richmond because i heard richmond and the nosiest gears out there
Old Jul 6, 2007 | 11:46 PM
NOTAV6's Avatar
i ran a 2 series carrier 3.73 gear for 2 years on a auto then converted the car to 6 speed, and then went to the track
6 speed and rear ends dont get along even still my gears were fine but it got the spider gears in the diff
youll be just fine on a 2 series 3.73 gear
Old Jul 7, 2007 | 01:47 PM
jakesz28's Avatar
I ran 4.10's in the series 2 for about seven years held in their like a champ until the sixyty foot hit a 1.483. ouch!
I never had a problem and the gear noise wasn't bad.
Turned out the spiders were the weak spot.
