My LT1 feels slow...
Old Jul 16, 2007 | 11:22 AM
LT1drifter's Avatar
Its a 2.73, I guess I'll look into getting some gears.
Old Jul 16, 2007 | 04:42 PM
silverbirdlt1's Avatar
since you have an auto, 3.73's would be the prime choice... i have 4.10's, and i do love them but the gas mileage sucks (about 21 is the best i have gotten all highway). The 3.73's will DEFINATELY wake your car up and you will still get decent gas mileage. just my $0.02.............
Old Jul 16, 2007 | 07:02 PM
speed_demon24's Avatar
Chirping or spinning tires isn't a way to judge a cars performance...
Old Jul 16, 2007 | 07:05 PM
LT1Formula007's Avatar
If you do alot of highway driving a really good gear would be 3.42. But if you don't care too much about that than 3.73 gears are really good. Another question to ask yourself is would you rather get a whole new carrier and gear kit for 500+ plus getting it installed for a few hundred $, or you can get a rear end out of a 6 speed TA, Formula, or Z28 with a stock 3.42/limited slip setup and put it right in. That would save u some $ also. (300-500 in a junk yard)
Old Jul 16, 2007 | 07:11 PM
White_Ls1's Avatar
Originally Posted by nomoneyz
x2 here. I cant spin at all with my 2.73s unless I power brake it.
My 89 IROC with a TPI 305 had 2:73's and it would spin them, Might want to check things out.
Old Jul 16, 2007 | 07:25 PM
I have 2.73's and I have no problems spinning the tires if I hammer it from a roll at like 10 mph with the shifter in first gear, but off the line I can't spin them for nothing, well unless I'm launching it at like 1500+ RPM. So don't feel too bad. The down fall is 2.73's are slow off the line, but the ups are like my times are consistent at 14.0 at 100 mph in the 1/4. Probably due to the car not spinning off the line. So u have your down falls as well as your ups. good luck with the car, if you wanna spin, buy some gears and mod the hell out of it
Old Jan 30, 2022 | 04:17 PM
Matta4810's Avatar
Default Yes
Originally Posted by Puck
Not normal at all. If its truely a 5.7 z28 LT1 replacement and not the "baby" lt1 it should definetly put more down. Must be ignition related, when I first got my Z the previous owner did a tuneup and had a plug wire that leaned against one of the pulleys and cut it, and was sluggish just like you are describing.
I would do an ohms check on all the wires and replace the plugs. Even bone stock it should shred the tires from a standstill.
I have a bone stock 94 25th anniversary T/A and it will most DEFINITELY shread the **** oushof the tires from a standstill. For a 28yr old car, its still badass
Old Feb 3, 2022 | 05:46 PM
DrumpJuan's Avatar
Originally Posted by Matta4810
I resurrect threads to explain how badass my 28yr old 14 second car is
Ok got that part. Question, how old is too old to resurrect a thread on stock lt1 acceleration?
Old Feb 4, 2022 | 09:56 AM
SS RRR's Avatar
Village Troll
Do a search first with key words. Some of us have been around since before Adam on this site and our minds were probably a bit fresher when it came to certain issues. If it doesn't come up then post about it. I honestly don't care because there's very little traffic on this site anymore...
