New motor progress!
Old Jul 16, 2007 | 08:54 PM
Ar0ck's Avatar
Default New motor progress!
Heres some pictures my shop sent me of my engine being removed. The stock short-block couldn't handle a CC306 w/ supporting bolt ons so I'm having them build me a new short block that will handle it and then some.
Out with the busted old!
Old Jul 16, 2007 | 09:00 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Good deal, clean outside but my god man clean that engine bay and underside of the car.
Old Jul 16, 2007 | 09:28 PM
fergymoto's Avatar
What happened with your stock short block?
Old Jul 16, 2007 | 11:38 PM
346Vette's Avatar
Might wanna sand and recoat those LT's while they are out.
Ditto, what happened to the old motor, is that oil everywhere???
Old Jul 17, 2007 | 06:30 PM
Ar0ck's Avatar
I *think* the stock motor spun a bearing. One day I was just cruising home and my dash lit up like a Christmas tree and I lost oil pressure. I immediately pulled over and was able to push the car home. I turned it on after I checked the oil and the usual stuff and it had an erratic idle with a tapping noise. So instead of figuring out all that jazz I went ahead and am having a forged motor built and installed.
The actual part of the engine bay that you can see is usually clean but underneath is just the stock LT1's under body lubrication system
Old Jul 17, 2007 | 07:45 PM
FlamingChicken's Avatar
My car had the auxiliary cooling system as well other than forged build what are your plans?
Old Jul 17, 2007 | 10:23 PM
the_merv's Avatar
Veteran: Air Force
Originally Posted by Ar0ck
You drop that a little different than I have seen..I drop the K-member by unbolting the bottom of the Shocks, less weight coming down..
It's still fun work.
Dremel off that AC Box, you won't believe how much room opens up back there..
Old Jul 17, 2007 | 10:39 PM
Z28_DAD's Avatar
if you break the box using channel locks it doesnt make a huge fiberflass dust mess. i learned that after the 3rd one ive done
Old Jul 17, 2007 | 11:34 PM
the_merv's Avatar
Veteran: Air Force
Air Compressor gets rid of that dust rather quickly..
Old Jul 18, 2007 | 12:17 AM
DroppedM6Z's Avatar
nice looking car. good luck with the install
Old Jul 18, 2007 | 01:25 AM
BizZzatch350's Avatar
Moderator
Good luck with the build, silver LT1 Zs are some of the best looking fourth gens
Old Jul 18, 2007 | 01:32 AM
the_merv's Avatar
Veteran: Air Force
It does look real sharp, even without the Badges. Nice Sleeper.
Old Jul 18, 2007 | 01:31 PM
Ar0ck's Avatar
Only if the lope of the cam didn't give it away
Thanks for all the compliments guys! I can't wait to get the car back on the road. Its been too long.
I don't plan on doing much more to the car since I want to enjoy it for once instead of it always being down.
Old Jul 18, 2007 | 02:11 PM
LT1MAN's Avatar
sweet ride man, i would highly suggest coating your headers now.
Old Jul 19, 2007 | 02:55 PM
Ar0ck's Avatar
Thats my winter project since I def will not be driving the car over the winter. I just want it back on the road, so I'm taking a short-cut for the rest of the season.
