oil capacity
Old Jul 20, 2007 | 02:19 AM
JTSLP559's Avatar
Default oil capacity
im about to change my oil.. an i realized i dont have a owners manual and i just got this lt1 auto.. an i have no idea how much motor oil it holds? its a 94 formula a4!
Old Jul 20, 2007 | 02:29 AM
alconk's Avatar
5 quarts including filter
Old Jul 20, 2007 | 02:43 AM
RickyMartinZ28's Avatar
Exactly 5 quarts with oversized Fram HP4 filter.
Old Jul 20, 2007 | 03:51 AM
transamws6_97's Avatar
it holds over 5 quarts with the oversized filter. I just buy a big 5 quart jug and pour most of it in then check but either way you should be right around 5 quarts
Old Jul 20, 2007 | 04:16 AM
93 blackformy's Avatar
Yea jus buy the 5 quart jug and like^^^^said check b4 ya empty it all in!
Old Jul 20, 2007 | 04:21 AM
Ralls's Avatar
6 quarts fills mine perfectly.
Old Jul 20, 2007 | 11:22 AM
JTSLP559's Avatar
ok sweet. i bought a 5 quart jug lol. what oil do you guys run in yours?
Old Jul 20, 2007 | 11:24 AM
Revelation Z28's Avatar
5.5 for me. damn PCV.
Old Jul 20, 2007 | 12:21 PM
JTSLP559's Avatar
haha, i just bought a cheap oil to put in it right now, the oil thats in it sat for 2 years. so i dont wanna put good **** in and have it all gross and grimmy.
so what oil should i do guys!?
Old Jul 20, 2007 | 12:27 PM
I run 10w-30 synthetic mobil 1. It's all personal preference which brand tho. You can also try using seafoam to help clean out some gunk in your crankcase
Old Jul 20, 2007 | 12:38 PM
LT1MAN's Avatar
mobil 1 synthetic is what most of us use. weight usually depending on your location.
Old Jul 20, 2007 | 12:55 PM
JTSLP559's Avatar
i live in 110 in the summer and 30s in the winter. i bought this gunk motor flush stuff, it was on sale at wallymart. i dont know if i should try it or not? what do you guys think?
Old Jul 20, 2007 | 12:58 PM
speed_demon24's Avatar
Just run 0W40 M1, it will clean out the inside of the engine itself. And mine takes ~5.75 quarts with the longer filter if I drain it with all 4 wheels in the air.
Old Jul 20, 2007 | 01:10 PM
JTSLP559's Avatar
ah ok cool, i will try that. is marvel mystery oil a good additive?
Old Jul 20, 2007 | 01:12 PM
The majority of oil addictives are a scam, just stick with a good quality oil.
Old Jul 20, 2007 | 01:13 PM
JTSLP559's Avatar
alright cool. thanks man
Old Jul 20, 2007 | 01:39 PM
borninatransam's Avatar
um for those that say they buy the 5 quart jug, that jug is only a gallon, and a gallon is only 4 quarts. you might want to look at that during your next oil change and get an extra quart to go with it.
Old Jul 20, 2007 | 02:34 PM
FAD2BLK93's Avatar
GM factory spec is 4.5 quarts with the filter...and 4 quarts without, all of you may be over filling your oil system...creating some drag on the crank=loss of horsepower. I personally use 20-50 royal purple with lucas oil full syn addative.
Old Jul 20, 2007 | 02:38 PM
nomoneyz's Avatar
Mine takes about 5.5 with a delco filter. Fills it up perfectly not over full at all. I use 5w30 castrol gtx
Old Jul 20, 2007 | 02:40 PM
dhdenney's Avatar
Especially Mobil 1, a lot of oil companies now make the 5 qt jug. All it takes is a second to look on the label to know how much you are buying.
