Headers and exhaust installed!
Old Jul 21, 2007 | 12:18 AM
Ironxcross's Avatar
Default Headers and exhaust installed!
I installed the headers (pacesetter longtubes) with a friend. Took about 16 hours with all the hang ups and breaks. Got the car back from the exhaust shop. I with the LTs, ORY, 3in/out cat, hooker aerochamber muffler. The car definately feels more powerful and still has a close to stock sound. The only issue is that it seems like the headers aren't sealing properly so im getting that nice header leak sound. Does that go away after retightening them a few times? I have the pacesetter y-pipe, its slipfit to the headers and the guy that installed the exhaust put some wrap around flange thing on it to hold it shut, could that possibly be an issue?
Other than that, the car is amazing and feels nice and ALIVE.
Old Jul 21, 2007 | 01:06 AM
transambandit's Avatar
might have the exhaust guy weld them on, would seal up the leak.
Old Jul 21, 2007 | 01:07 AM
Ironxcross's Avatar
i was thinking about that, but i wanted to have them where i could remove the y-pipe if need be for repairs
Old Jul 21, 2007 | 03:34 AM
Ralls's Avatar
Where's the leak? Flange or at the collectors? What kind of clamps do you have? I got band clamps that seal the gap between the slip fit.
I wouldn't get anything welded on the exhaust. I've had to take my exhaust off several times to do whatever to my car. It's much easier if it's not all one piece.
Old Jul 21, 2007 | 06:57 PM
Ironxcross's Avatar
i think the leak is at the header gaskets, i tightened them down like crazy but they still leak. i got the kind that are embossed for the header ports. any ideas other than tightening them down more?
what kind of gasket did you use?
Old Jul 21, 2007 | 08:44 PM
Ironxcross's Avatar
https://securehost98.hrwebservices.n...&productId=163
Old Jul 21, 2007 | 09:49 PM
well the only thing i could think of is that the gaskets are a little off, i would check under the header with your finger and make sure they didnt slip out a little bit or are a little bit off-center, that could cause a leak.
Old Jul 22, 2007 | 12:22 AM
Ralls's Avatar
Did you ever notice the header flanges warped/bowed?
Old Jul 22, 2007 | 01:34 AM
Ironxcross's Avatar
im starting to think that the gasket is junk, its too much for the tiny header bolts to torque down. im going to get a flat gasket and see if its different
Old Jul 22, 2007 | 02:01 AM
the fel pro ones from autozone do the trick quite nicely and are way cheaper.
Old Jul 22, 2007 | 01:40 PM
dangalla's Avatar
+1 or get a stock oem replacement
Old Jul 22, 2007 | 09:11 PM
Ironxcross's Avatar
i just bought some felpro replacements, im going to do the drivers side tomorrow, see if it makes a difference.
Old Jul 23, 2007 | 12:47 AM
REBORN Z28's Avatar
Clamps=JUNK. Weld everything up with the exception of the connection to the headders and the cat to the rear portion.
