Any sponsor vendors sell a neutral balanced LT1 M6 Flywheel?
Originally Posted by hyperzone
Would like to know if there's any noticable difference. I have a rebuilt motor that is supposedly "balanced"... Never heard anything about not using the stock flywheel before.
Well... I said ASAP but it sure took awhile. I actually got it installed Sept 28th(Saturday). This is where it gets strange. I mentioned the vibration I'd had from the motor from day one and I'd concluded it was because of the flywheel never being neutral balanced while the shortblock had been setup for neutral balance. Well, I got everything ready and disassembled, took off the removable counterweight from the SPEC flywheel and installed it. When getting the starter ready to bolt back on, I noticed I could see the counter weight bolt holes thru the starter hole. I put the starter on, then finished everything else and then started the car to experience the expected buttery smooth idle. Oh hell no... damn... If I thought it was vibrating BEFORE then this was a farking earthquake at idle. The gear shift lever on my PRO 5.0 shifter looked like rivet gun hammering away. I cussed, turned off the key and sat down pondering what had just happened. I thought and thought and then decided on a whim to pull off the starter and then set the counterweight bolt holes in that same place I'd seen them earlier and reattach the counterweight. I did so then started the car. Well I'll be damned. Smooth as butter. WTH? I can only surmise that the engine WASN'T setup for neutral balance. I can now rev with abandon to 7K and it's fine. I'm really enjoying the car now, FINALLY after all this time.
