suspension set ups
Old Jul 24, 2007 | 09:00 PM
cruzin94's Avatar
Default suspension set ups
i was wondering what is the best suspension parts and what are good set ups for street and strip cars eventually pushin 400-500 rwhp any help would be appreciated
Old Jul 24, 2007 | 10:37 PM
96redcamaro's Avatar
I like QA1's. that is what i have on my car. I have R's up front and F's in the back. with 300lb springs.
but I have not gotten to drive my car yet ... but i will friday
Old Jul 25, 2007 | 12:27 AM
seawolf06's Avatar
Depends on what you wanna do with the car as well. Mostly street and some drag, all drag, some road race, etc. How low you wanna go will depend on how bad the streets are where you live and how much you want the bottom of your car banged up.
Old Jul 25, 2007 | 01:09 AM
transambandit's Avatar
Konis are good too, and eibach springs are great.
Old Jul 25, 2007 | 01:35 AM
94'BLKBRD's Avatar
get eibachs for sure
Old Jul 25, 2007 | 01:44 AM
nighthawk15's Avatar
For shocks go with Konis or Sam Strano's revalved Bilsteins. For springs pick yourself up an Eibach pro kit maybe. Avoid Sportlines though. Sam Stranos springs are good also and very road racing oriented. what all are you wanting to do anyway?
EDIT: If you are lowering you will also want an adjustable panhard bar, and control arm relocation brackets are highly recommended. You can use the brackets with the stock LCAs if you wish, but I really do not recommend it considering that the stock peices are monumental **** to put it bluntly. UMI is a great company to pick up the adjustable panhard bar, LCAs, and relo. brackets from.
Old Jul 25, 2007 | 08:02 AM
BlackScreaminMachine's Avatar
Internet Mechanic
The street is the great equalizer, your not going to run the best but having a good drag radial, shocks/springs, tq arm with LCA's and relocation brackets are going to be a good step in the right direction.
Old Jul 25, 2007 | 08:50 AM
LT1MAN's Avatar
your definately going to want to get a torque arm, i run the adjustable edelbrock and hooks very well with UMI lca's and panhard and bbk upper panhard relocation.
Old Jul 25, 2007 | 02:02 PM
LT1Z/28's Avatar
BBK makes an panhard relocation, were did you get that at?
Old Jul 25, 2007 | 05:18 PM
cruzin94's Avatar
what helped make you guys hook up the best ...besides slicks...i was thinkin 3 point subframe connecters, tourqe arm, lca's and pan hard bars ....do spring make a huge diffrence ...i dont really want to lower my car either
Old Jul 25, 2007 | 06:07 PM
Probably the best first mod for hooking up is LCAs with relocation brackets, then some subframe connectors and a torque arm. The brackets for the LCAs still help even if your car is not lowered. For straight line performance if your shocks are not worn out yet I would just keep them for now and replace them with some Koni's when they're shot. You only need springs if you wanna lower it or your stockers are worn out.
