maf and tb ?
Old Jul 20, 2007 | 08:51 PM
97 ramair's Avatar
Default maf and tb ?
maf, should i just get the ends or new bigger one ?
tb, 58mm or ? foil ?
how much gain ?
Old Jul 20, 2007 | 09:01 PM
Revelation Z28's Avatar
leave the maf alone.
the throttle body id leave alone too until you get your intake port matched to the 58mm tb.
Old Jul 20, 2007 | 09:06 PM
97 ramair's Avatar
so a maf and tb bolt on won't do anything ? i need a ported plenum ? aftermarket ?
Old Jul 20, 2007 | 09:10 PM
the opening on the stock intake manifold will support up to 52mm. after that you need to port the holes to accomodate the bigger TB openings.
the maf is good for 400hp or so. i wouldnt touch it.
Old Jul 20, 2007 | 09:39 PM
97 ramair's Avatar
how about the maf ends and foil ? aftermarket intake plenum ?
Old Jul 20, 2007 | 10:11 PM
koolaid_kid's Avatar
I went with an aftermarket MAF and a 52 mm TB. The MAF is gone, the TB (ported stock) was one of the biggest performance improvements to my then stock car. Now that I have the turbo, I am extremely glad that I did it.
Old Jul 20, 2007 | 10:20 PM
InsaneAuto86's Avatar
I noticed a difference with my 52mm tb. I also have ported MAF ends (stock sensor).
Old Jul 21, 2007 | 12:49 AM
LiENUS's Avatar
MAF is good to closer to 600hp or so, its a slight restriction but the tables go all the way up to 610hp worth of air (n/a).
Old Jul 21, 2007 | 06:21 AM
97 ramair's Avatar
sounds like the best bang is the foil $20. and maf ends $70. thanks guys.
Old Jul 21, 2007 | 09:06 AM
96capricemgr's Avatar
Ignore anyone who tells you to buy MAF ends or to port the MAF. Airfoils are a waste too.
Ported plenum is a waste on as cast heads, once heads are ported it is fine.
You are chasing all the wrong things here.
Hypertech "programmer" is garbage, overpriced garbage at that.
Looking at your mod list in your sig I would say headers is the next thing to do, so stop looking to waste money on piddly little junk that wont do anything and save a few bucks for headers.
A 52mm TB might be worth a SLIGHT amount on a stock engine BUT IMO those who claim it was great are confusing throttle response with power. The bigger opening means more air/power for the same slight throttle openings, at WOT though a stock engine is not signifigantly restricted by a stock TB especially not with stock exhaust manifolds choking it.
Old Jul 21, 2007 | 09:24 AM
GIZMO's Avatar
For the record, the stock throttle body is good for 500+ FWHP. An airfoil is worth nothing. Removing restrictions ahead of the throttle body will show some slight gains.
Good Luck,
Daren
Old Jul 21, 2007 | 11:35 AM
if you get a 58mm tb you DO need to port the opening on the intake anyways. i just pointed out to him that he would need to do that if he got one.
Old Jul 21, 2007 | 01:21 PM
Interesting. My car had a CAI and a catback. It would lay 10 feet of rubber from a dig. I put on a ported stock TB. It immediately would lay 20 feet of rubber. No other changes at that time, including tires and tire pressure.
Old Jul 21, 2007 | 02:13 PM
The opening aint the plenum, he asked about a ported plenum so yourself.
koolaid_kid, so do you think you doubled power or what? Road surface and temp can have a huge impact on traction.
I find the
especially laughable. The point of boost is to compress air and force it though a restriction under pressure. A mildly boosted car would benifit LESS from a bigger TB than a heads/cam one, because the air is compressed.
You people need to learn how to think not just read advertizements and catalogues. Reason things through, ask how and why. For instance once you understand HOW a MAF works you will understand WHY changing the ends or porting it is such a terrible idea.
The newbies have to sort through all this stuff and ask questions, we were all there once, it is not their questions I object too but the number of idiotic responses they recieve.
Old Jul 21, 2007 | 03:00 PM
GIZMO's Avatar
I find the especially laughable. The point of boost is to compress air and force it though a restriction under pressure. A mildly boosted car would benifit LESS from a bigger TB than a heads/cam one, because the air is compressed.
I don't know a lot about boosted motors, but I would have thought that a larger throttle body would be a big plus in any boosted application. My guess is that it would make for smoother (less turbulant) air flow to the cylinders. Any boosted experts reading?
Old Jul 21, 2007 | 03:01 PM
GIZMO's Avatar
That is about the least scientific test that I have ever read on this forum!
Old Jul 21, 2007 | 03:12 PM
The LT1 That Could's Avatar
Buy some LTs, and quit dicking around with pointless bolt-ons!
Old Jul 21, 2007 | 03:20 PM
streetwarrior96's Avatar
Old Jul 21, 2007 | 03:37 PM
Didn't say it was scientific, now did I? Same car, same stretch of road, different performance. I have not seen any scientific proof from the other side of the fence either. Just be nice GIZMO, there has not been any scientific evidence on either side.
Old Jul 21, 2007 | 03:44 PM
97 ramair's Avatar
thanks guys. so headers huh ? which one ? has to be carb legal. thanks again. tom.
