It's on now..
Old Jul 31, 2007 | 01:20 AM
the_merv's Avatar
Veteran: Air Force
Default It's on now..
I had a cooling problem at the Track last weekend..it over-heated after a pass. I installed both Fans in the Factory positions, set them up to where both come on with a Manual Fan Switch. Both Fans are powered by a circuit I setup using the Factory Relays, so it's not straining the car any.
I took it out earlier tonight and ran the dog **** out of it..I ran it up to 120mph(got there pretty quick..) and came down to a stop, turned around and did the same a few times in a row on a back road, it didn't get above 220 the whole time. I have the Temp Sensor positioned in-line on the Heater Core Line coming out of the Water Pump..basically the hot side of the Engine.
It's money now..
Old Jul 31, 2007 | 01:56 AM
JTSLP559's Avatar
awesome man good to hear, my car still runs at 235 idleing before the fan comes on.. normal driving itl see 210-220
Old Jul 31, 2007 | 05:32 AM
camar0corey's Avatar
Nice. Maybe those there GM engineering folk knew where to put them thar fans.
Yeah about the temps when the fans come on stock...... I have a manual fan switch, and my A/C wasn't working, it was way low, but the guy tried to tell me that running the fans before they are supposed to come on sets a code. I never heard of it, as I had run it that way for 2 years before any issues.
Hopefully that the last bug in your system there, when will it be all out time?
Old Jul 31, 2007 | 05:34 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I dont know how many miles you have on it but I will bet my bottom dollar, you need a radiator. I had delt with that issue and replaces every part except the 102k original radiator. Once I did, I never had a issue of overheating, it radiator had pin hole leaks that I only found out after having the radiator hot tanked at a shop.
Old Jul 31, 2007 | 06:48 AM
92LT1RS's Avatar
+1 had the same problem a few years ago on my '92. got the radiator rodded out and cleaned up, never had a cooling issue since.
Old Jul 31, 2007 | 07:34 AM
LT1MAN's Avatar
yep, me3
Old Jul 31, 2007 | 12:18 PM
the_merv's Avatar
Veteran: Air Force
I am looking into it..if I do change Radiators, I am getting an LS1 one..that way everything matches.
Might possibly have 1/4 mile results Thursday..
Old Jul 31, 2007 | 12:29 PM
Red96TA's Avatar
Hell yea!
Old Jul 31, 2007 | 04:57 PM
1994Z28Lt1's Avatar
are you talking putting a stock ls1 radiator in there? i've always heard that the lt1 radiator is better because it has a thicker core something like 1-3/8th inch core on the lt1 rad and like 1 inch on the ls1 radiator
Old Jul 31, 2007 | 05:40 PM
ZFan88's Avatar
Get a BeCool, they're cool
Old Jul 31, 2007 | 05:42 PM
vtec's Avatar
Resident Racing Jerk
i dont remember a difference between my LS1 radiator and LT1 radiator.......
Old Jul 31, 2007 | 06:22 PM
the_merv's Avatar
Veteran: Air Force
I have heard the same..might stick with the LT1 one..
I also put an extra PCV Breather on it..it even runs cooler now..
