Battery Problem??
Old Aug 3, 2007 | 08:06 PM
BizZzatch350's Avatar
Moderator
Default Battery Problem??
Car wouldn't start, turn the key forward it acts like its a low battery, starter makes noise but wont crank the motor over. Noticed the lights dim when I turn the key forward and try to start it, figure thats normal for a low battery, but the speedometer goes up to when I crank it. Kinda threw me off, to maybe I have a issue else where.
Old Aug 3, 2007 | 08:32 PM
LT1Falcon's Avatar
well why dont you just get 12 volts of power to it and see if it fixes it?
jump start it, get a battery charger, or borrow a battery from another car
Old Aug 3, 2007 | 08:42 PM
Moderator
Well to my luck I think my battery charger just died, gonna pull the battery tomorrow morning and have it put on a real battery charger, see if that fixes it. I need to start putting it in the garage backwards so I can actually jump it with another car, you would think I would have learned my lesson by now.
Old Aug 4, 2007 | 07:59 AM
LT1Falcon's Avatar
lol yea. you could just take the batter out of another car and carry it to the front of yours, then connect them
Old Aug 4, 2007 | 07:05 PM
Moderator
Looks like its a bad starter, charged the jumper up, tested the batter it said it had power, went to start it, starter just clicked a lot. After that tried again, stopped clicking just saw the lights turn out when I turned the key forward, starter wont even click now. Time to yank it.
Old Aug 4, 2007 | 08:51 PM
LT1Falcon's Avatar
yea sounds like the problem
Old Aug 5, 2007 | 03:14 AM
infinitebird's Avatar
check the terminal voltage while cranking, that should tell you if it is the battery.
Old Aug 5, 2007 | 03:25 AM
Moderator
Well I was able to get enough charge from the jumper box to get the starter to almost crank the motor. I need to find the voltmeter and see whats up with it.
