whose got the fastest LT1
Old Aug 7, 2007 | 08:52 AM
  #41
Mike96z's Avatar
Originally Posted by Speed Density
What the hell are you talking about?
Reverse Cooling, Optisparks, Firing order its all still OEM. Just more cubes.
Tony.
Think of it as an LT1 on steroids.
Old Aug 7, 2007 | 12:26 PM
  #42
Next level's Avatar
Originally Posted by burnzilla
Since we are talking about 383's and 396's, I have a question for you guys who have done this.
What kind of HP/Tq increase would say, a bolt on car get from just going to a full 383/396 Rotating Assembly?
Dyno-Flo's 383 Kit: $699.00
-Good to 500HP
-Eagle Cast Steel / Nodular Iron Crank 3.48 Stroke
-2pc rear main seal 3.75 (external balance)
-Probe FPS Forged Pistons Flat Top 10:8 64cc
-Eagle SIR Press Pin 5140 Forged Steel rods 5.7"
-Mahle Moly Performance Ring Set
-King Performance Bearings Rods and Main
And what is the difference between a crank with a 3.48 stroke, compared to a crank with a 3.75 stroke? How does this affect the hp/tq curve?
i got a 396 mild ported heads and stock manafiold push 420HP 460TQ.
- custom ground cam .575/.595 lift
- eagle crank
- 2800 stall (need bigger )
- 3:73 richmond/ Eaton Carrier
- Dnyatech LTs
etc......
Old Aug 7, 2007 | 12:33 PM
  #43
T/A KID's Avatar
*watches as everything I just said flies over your head*
Whatever you want man, lol. Better that nonsense to Fly over my head than into it .
Old Aug 7, 2007 | 02:16 PM
  #44
TwoFast4Lv's Avatar
Originally Posted by Tony Shepherd
omg thats funny.
ANd here I thought I was ok running factory modified heads, Intake and block
Old Aug 7, 2007 | 06:12 PM
  #45
jakesz28's Avatar
Originally Posted by Next level
hey 11.78 on a 10 bolt im just trying to find out what is the fastest documented 10 bolt went thats all.
Mine maid 1 pass at 11.002 and several at 11.20 alot more 12.5's but in the end it is still broken.
Old Aug 7, 2007 | 07:14 PM
  #46
Ed Wright's Avatar
9-Second Club
Ken Anderson ran something like 11.40s before he broke his 10 bolt, two or three years ago. Just heads & cam at that point. Not much more than that now, (.030" over) and ran several 11.ohs @ 122/123 this spring. Rear end doesn't matter, it's just how lucky you are and for how long.
Good one Ellis!
Old Aug 7, 2007 | 08:10 PM
  #47
burnzilla's Avatar
- eagle crank
- Dnyatech LTs
etc......
So, what about if your heads were not ported, and you had no cam?
Just bolt ons with a complete 383 Rotating Assembly...
