Installing CC503
Old Aug 7, 2007 | 12:12 PM
95N20FORMULA's Avatar
Default Installing CC503
What all needs to be replaced, and can u give me a list of parts ill need...like the exact size and everything
Old Aug 7, 2007 | 12:53 PM
of yea and whats the power band on the cc503 cam and can someone give me a link of where to buy it
Old Aug 7, 2007 | 10:58 PM
97LT1's Avatar
If that does not work here, go to cz28.
Your going to need upgraded valve train parts. Springs etc.
Old Aug 7, 2007 | 11:12 PM
StealthFormula's Avatar
This is what I did with my swap:
Comp Cams Self-Aligning Magnum 1.6RR's
Trickflow Hardened Chromemoly Pushrods 7.2"
Crane 10308-1 Springs
New Timing Chain
New Optispark (might as well when your there)
Old Aug 7, 2007 | 11:33 PM
1994Z28Lt1's Avatar
dont forget about things like intake manifold gaskets, timing cover gasket, new timing set, a puller to remove crank hub, valve cover gaskets (although being rubber they can usually be reused) the possibility of needing new lifters, dont forget about leaving enough money to get the computer tuned, along with things that have already been listed
usually from what i've seen the majority of people produce peak power at around 5800 rpm
Old Aug 7, 2007 | 11:34 PM
so would i be good taking it to 6000
Old Aug 8, 2007 | 12:44 AM
compt/aclone's Avatar
this seems to be the same cam as mine.....thought you were going bigger
Old Aug 8, 2007 | 09:23 AM
it is alittle bigger whats ur lift and duration....
Old Aug 8, 2007 | 09:27 AM
i believe this cam is 228/230 and like 540....
Old Aug 8, 2007 | 09:40 AM
536, 544 on 112
Old Aug 8, 2007 | 10:02 AM
i didnt realize urs was even that big, i may go with the Gm847 cam then its a 234/242 with like a 570
Old Aug 13, 2007 | 10:52 PM
southern_chevy's Avatar
I have a use cc503 for sale if you are interested pm me
