Front engine oil leak please help.
Old Aug 12, 2007 | 10:52 PM
mybluez28echoes's Avatar
Default Front engine oil leak please help.
I want to replace the front oil seal on my 95 LT1 engine. Do you know of any website that shows detailed pics to help me do that as I never did it on my own.
I'm having some kinda oil leak from the front of the engine, not too bad but I hate to see it, I see it around the timing chain cover and all the way down, I'm assuming it's the front seal, correct me if you think else please.
Thanks a lot
Old Aug 12, 2007 | 10:57 PM
Revelation Z28's Avatar
try www.shbox.com
if its coming from the crank area then its the front main seal. you would have to pull the balancer and hub off to replace it.
timing cover gasket youre gonna need a whole weekend and a 24 pack
Old Aug 13, 2007 | 12:34 AM
ZONES89RS's Avatar
In-Zane Moderator
Nothing a lil power tools cannot help with.
Old Aug 13, 2007 | 12:51 AM
the_merv's Avatar
Veteran: Air Force
Originally Posted by Revelation Z28
try www.shbox.com
I don't know about that my friend..that's about a days work, and that's factoring in the bullshittin and breaks..
Old Aug 13, 2007 | 12:54 AM
ZONES89RS's Avatar
In-Zane Moderator
Couldnt say it any better Merv. +1
Old Aug 13, 2007 | 12:56 AM
the_merv's Avatar
Veteran: Air Force
Thanks..I would of said 5 hours, but I do alot of bullshittin, and I drink alot of beer..
Old Aug 13, 2007 | 01:13 AM
i wanted it to sound a little scary at first. but for a first timer dealing with the opti. then all the cursing before/during/after the job. throwing a bolt because it wouldnt go on right the first time, and taking half a day to find where you threw it. i think a weekend should be plenty of time
Old Aug 13, 2007 | 01:29 AM
ZONES89RS's Avatar
In-Zane Moderator
A first timer that does work on their own **** err maybe does it for a hobby, 7 hours if you were serious on the first try.
Old Aug 13, 2007 | 10:39 PM
well, as for the beer it's always there and believe it or not, it helps my brain function better ******* with the LT1.
As for a first timer, replacing this thing is a first timer job, but I've done almost everything else on my Zee, will that cut my time down to 8 hours and a case of beer? I'm light weight people, I can't drink 24 pack , go ahead and call me a WOSS now ;-)
Old Aug 13, 2007 | 10:44 PM
iceman15's Avatar
check out this link, it helped me alot. very good writeup http://www.impalasuperstore.com/nais...TOPIC_ID=30984
Old Aug 13, 2007 | 11:20 PM
the_merv's Avatar
Veteran: Air Force
It's really not that bad to do..
Oh yea.. Wuss..
J/P
