oil level sensor
Old Aug 11, 2007 | 05:04 PM
Revelation Z28's Avatar
Default oil level sensor
who carries them? mine has been leaking prefusely.
Old Aug 11, 2007 | 06:51 PM
Paul Bell's Avatar
That's MISTER MODERATOR
GM.
Here, about 3/4 the way down: http://shbox.com/1/Parts.htm
Old Aug 11, 2007 | 07:41 PM
1redta's Avatar
Default re
you could get a plug for it as long as you know the level/ use of oil for your engine, I think Canton makes plugs
Old Aug 11, 2007 | 10:27 PM
i need to get one tomorrow.
Old Aug 11, 2007 | 11:25 PM
Paul Bell's Avatar
It's a 20MM X 1.5 thread.
Old Aug 11, 2007 | 11:45 PM
well a sensor im not gonna plug it up.
Old Aug 12, 2007 | 06:48 PM
hyperzone's Avatar
Default hope this helps...
GMpartsdirect is where I got mine from only like 6 months ago. I just took a look at the LS1tech part number listing and tried searching for the current and former part numbers and GMpartsdirect doesn't seem to have either one and says to call their customer service number. I guess you gotta call'em or call a dealership.
Old Aug 12, 2007 | 10:22 PM
i got one from kragen. thank god.
anyways the newer ones come with a O ring already on them because my old one had a washer with a rubber gasket where it mates to the oil pan. i didnt put that back in.
my old sensor was putting oil all over the electrical connector when i took it out. good thing i swapped it.
Old Aug 12, 2007 | 10:25 PM
Imnotfast's Avatar
Found using thread sealer takes care of any and all leaks.
