How to change struts?
Old Aug 13, 2007 | 10:12 AM
lilblackZ28's Avatar
Default How to change struts?
I need to replace my struts and I dint know if it would be easier to someone put them on or if i was able to put them on.
Old Aug 13, 2007 | 11:05 AM
LT1MAN's Avatar
i guess it depends on your level of experience, tools, tolerance of frustration, etc...
Old Aug 13, 2007 | 11:31 AM
Hot94Z28's Avatar
Here is a link so you can get a idea:
http://www.ls1howto.com/index.php?article=6
Old Aug 13, 2007 | 01:36 PM
1SlowFormula's Avatar
I just did mine this weekend and that writeup would have been helpful since I pretty much just went at it myself, but it wasn't too hard if you know what your doing...
Old Aug 13, 2007 | 01:43 PM
ZONES89RS's Avatar
In-Zane Moderator
Unbolt the old ones, bolt up the new ones, J/K, if you dont do your own wrench turning you might as well not do that ither.
Old Aug 13, 2007 | 02:28 PM
ckyconan2003's Avatar
rent a spring compressor from autozone. its like $40. compress the springs and remove the top bolt. replace spring on new strut. and decompress spring and reinstall
Old Aug 13, 2007 | 03:11 PM
racerns's Avatar
First, find a car that has struts. Our cars have shocks.
Taking the shock-spring assembly out of the car is pretty easy, but getting the spring off and be a problem as the nut on top of the shock can be get very rusty and hard to get off. Take it to a shop that will compress the spring and swap the shock out for you.
Old Aug 13, 2007 | 05:24 PM
James Montigny's Avatar
The rears are easy, the fronts are a bit of a pain.
The howto writeup is very helpful.
You can generally bribe a local board member with beer to help
(to be consumed after the work is complete)
