what kinda numbers?
52mmtb
tb bypass
lt4 intake mannifold
lt4 hotcam
tbi harris performance chip tuned for my specs
lt headers dumped
cold air intake egr delete
stock gears and stock auto trans
just was looking for an estimate or someone close to this
I would say more on the 320 side of that though.
A 93 auto is one of the lower stock dynoing lt1s out there.
Also that the stock gears and a stock stall would be a BIG mistake.
EGR delete is worth exactly zero HP.
All this bad info gets spread around beause people just answer the question rather than setting the noobs straight.
-cai
-hot cam
-LT headers
-tune
i go with what infinitebird said " 320rwhp"
i think you should have put drag radials on that list, thats where youll see gain at the track.
If a noob posts a thread to the effect of "does this combo work?" and it clearly doesn't, then by all means I have no problem setting them straight. Otherwise, I figure if there is something "off" in their setup and it will take longer than a few sentences to explain it, they will probably figure it out or they can post a question pertaining to that.
Nothing wrong with showing a little tact to the noobs. Besides it's not like there is always one right answer. Even experts frequently disagree.
Do you think stock gears, stock tranny which sounds like it means stock stall, are the right parts?
These are not parts that there are differing opinions on. It is fact the LT4 intake is internally the same.
It is fact that a cammed car will drive and perform MUCH better with a gear and stall upgrade.
I made the mistake of cam before stall and gear, I do not like seeing people make mistakes even if I made them myself.
i would try maybe some more research because there are IMO better choices out there than a lt4 hotcam as well. you will also want to address your valvetrain when doing any cam upgrade along with quite a few little details and "while i've got it apart" type stuff. and like stated above you're car will be much more enjoyable with gears and a stall. Good Luck.
im doing heads and a cam, and more boltons without them yet :X
im putting them on as soon as i can drive to the shop though
id say definitely get gears, a stall, RRs... etc etc
