i hate optis
Why so many failures?
I took my first extended trip this weekend with the new "Ebay" opti - about 250+ miles and I gotta say - I was sweating potential failure with every mile.
http://s136.photobucket.com/albums/q...t=100_5355.flv
http://s136.photobucket.com/albums/q...t=100_5358.flv
A distributor of any kind will missfire if it gets wet internally, and the cap and rotor are wear items, just like sparkplugs, the spark across the gap causes corrosion and wear.
These are details most of you seem incapable of grasping, therein lies the real problem.
Since it is not a $15 cap and rotor like an HEI everyone neglects it rather than preventatively replacing it. Which is fine, but when at 100K or whatever when it begins to act up don't bitch about it, that is a hell of a long time to leave a cap and rotor on any distributor. Replace it(cap and rotor) and IF YOU DO IT RIGHT it will be just fine for many many more miles.
But... I have read many threads about new optis costing hundreds of dollars arriving defective, or failing within hundreds of miles. And these are not all bargain basement chinese knockoffs.
Of course everything has a failure rate built in - especially electronics. But there is a lot of mechanical failures and it seems skewed to the high end on this part.
Kinda odd how they're hit and miss, but I guess could be conditions subjected to as well. My first lasted 104K and yours nearly double that.
