What next?
Old Aug 23, 2007 | 12:38 AM
GreenBlood's Avatar
Default What next?
I am going to be buying a 160 t-stat and an aluminum intake elbow this week. What would you guys recommend next, mods in sig? I was thinking either 3.73s or changing the the exhaust to the TSP rumbler with a powerstick, or just buying a powerstick and dumping it...Anyone around here running a single dump? The 2OTL exhaust sounds good, but its just not loud enough for my taste...Also, is the almuminum intake elbow worth it, or am i better off with the 1LE elbow?
Old Aug 23, 2007 | 12:41 AM
ZONES89RS's Avatar
In-Zane Moderator
Ditch the system to save weight, under drive, air foil and 1.6 rockers with springs.(system is useless weight.)
Old Aug 23, 2007 | 12:44 AM
GreenBlood's Avatar
i know the system kills weight, but it came with the car, and it sounds good...i love the bass it produces, and saves me the effort of putting weight in the trunk in the winter...with the system and me in it, the car weighs about 3700lbs...I could ditch it and put that thunderform box in the side wall i guess
Old Aug 23, 2007 | 02:53 AM
ZONES89RS's Avatar
In-Zane Moderator
Do whatever makes you happy man, thats all that matters.
Old Aug 23, 2007 | 06:22 AM
LT1MAN's Avatar
i dont think i could part with my stereo either. when i had the mods you have, my next mod was a hurst comp plus short shifter with a short stick. that is still one of my most favorite mods. something you will enjoy every shift. although i cant tell if you are m6 or a4. gears are also a good mod for what you currently have. also, an adjustable torque arm and lower control arms are inexpensive but produce good results.
Old Aug 23, 2007 | 07:18 AM
GreenBlood's Avatar
sorry, i am an A4...right now i can chirp the tires,which I am pretty sure is due to the weight of the system...I think with some 3.73s I could burn em up. I am positive I only have 2.73s because my shifter only goes down to 2, and at 70 mph i am only turning 1600 rpms...
Old Aug 23, 2007 | 08:38 AM
9730thanvz28's Avatar
yikes weight for the winter? isnt that what a beater car is for?
Old Aug 23, 2007 | 08:42 AM
LT1Falcon's Avatar
thats the first time ive seen anybody suggest an airfoil
Old Aug 23, 2007 | 08:52 AM
LT1MAN's Avatar
air foils are ok if you dont pay more than say $5 shipped
Old Aug 23, 2007 | 09:04 AM
Hot94Z28's Avatar
What about a Stall? Since your a A4 it would the next mod I would do.
Old Aug 23, 2007 | 10:55 AM
GreenBlood's Avatar
i was thinking about 3.73s and then asking for a stall for christmas...no winter beater for me, this is my only car, and it will be with me through thick and thin as I finish up school...i drove my B4C all winter when I had it...never had any problems, of coure I wouldn't drive if it was a whiteout, lol...next on the list is to save for a set of blizzaks or some other sort of winter tire...i have time for those, it doesn't start snowing here until late november...
Old Aug 23, 2007 | 12:02 PM
ZONES89RS's Avatar
In-Zane Moderator
Well, i kina do the air foil+under drive=a little gain. At the price you get both you can a bit and the dollar per HP gain is not too far off, every little bit counts, i will not suggest an air foil without under drive and that other way around.
Old Aug 23, 2007 | 01:48 PM
LT1Falcon's Avatar
i dont understand, does one benifit the other? either way, you are gonna pay 50+ dollars for 1 or 2 hp (air foil)
Old Aug 23, 2007 | 09:01 PM
GreenBlood's Avatar
if i go with a stall, what would be the best speed...the car will eventually be cammed with a 383 stroker, pending funds...i was thinking 3200 or 3600?
Old Aug 23, 2007 | 09:13 PM
GreenBlood's Avatar
would 2.73s work ok with a stall...from what i keep reading, i'll have to keep buying gears because they'll eat the differential over time...should i just buy a stall and then wait for the gears when i save for a 12 bolt or 9 inch? or is it worth it to do the 3.73s now, my car isn't making that much power over stock, i just want it quicker off the line...
Old Aug 23, 2007 | 10:01 PM
cruzin94's Avatar
well i just bought gears ihave whats in my sig and im waitin on the install right now but every one i talked to says gears will make a HUGE improvment over our 2.73's... then all ill need are some drag radials
Old Aug 23, 2007 | 10:45 PM
GreenBlood's Avatar
thanks
Old Aug 23, 2007 | 11:15 PM
ZONES89RS's Avatar
In-Zane Moderator
50$?!?!?! I paid 22.50, where the hell are they ripping people off for that much???
Old Aug 24, 2007 | 01:33 PM
GreenBlood's Avatar
bump for stall speed recommendations...eventually a 383 stroker will be in here...
Old Aug 24, 2007 | 04:53 PM
GreenBlood's Avatar
bump...
