How much fuel pressure is normal?
Old Aug 23, 2007 | 11:51 PM
alconk's Avatar
Default How much fuel pressure is normal?
I just hooked up a fuel pressure gauge and at idle and driving around it's right at 39 psi. It does go up when accellerating to about 42 psi and it's a stock unit. My car is equipped with a Hot Cam, tune, LTs, no cats or emmissions. I am running a 3.73 gear and the fuel system is all stock. Are my stock injectors ok for this application? My throttle body is also stock too, I was told that the stock 48mm is good for 350 horse so I figured I was ok there but I'm kinda worried about the fuel pres.?????? I have noticed that when the car is hot and has sat for awhile it starts ok but takes a couple revolutions before it fires as where in the morning when its cold it fires immediately.
Old Aug 24, 2007 | 12:26 AM
koolaid_kid's Avatar
Your fuel pressure is fine. It should be about 43 during a vacuum drop (accelerating) and about 3 less at idle, but the standard, non-adjustable FPR is not that accurate.
Your stock injectors should be fine for your engine in its current state.
Old Aug 24, 2007 | 01:27 AM
Formula350's Avatar
Yep 43psi. Unplug the vacuum line to check it's real PSI.
Old Aug 24, 2007 | 02:15 AM
Formula_LT1's Avatar
I think GM recomends like 6 pounds per thousand RPM.
Of course thats a minimum # I'm sure.
Old Aug 24, 2007 | 11:01 AM
buffman's Avatar
^^ That's for oil pressure silly.
Old Aug 24, 2007 | 11:18 AM
blown69ls1's Avatar
GM oil pres, 10lbs for every 1,000 RPM. Thats a normal app.
Old Aug 24, 2007 | 11:20 AM
buffman's Avatar
LT1 bare min is 6lbs @ 1000rpm last few times I've checked the old FSM. Reguardless figure he posted is not any relation to fuel pressure
Old Aug 24, 2007 | 04:05 PM
My bad. I thought I read oil pressure.
