Have a problem.
Old Aug 24, 2007 | 09:39 AM
mack's Avatar
Default Have a problem.
Bought a 58 mm TB. My intake was supposed to have been bored to 58mm when I had my cam done. Well, just took off the old TB and the intake is not bored to 58mm. Will it hurt the performance of the car to put the 58mm on or should I just put the old TB back on? Intake holes are currently 50mm.
Old Aug 24, 2007 | 10:06 AM
koolaid_kid's Avatar
Actually, stock is 52mm.
It should not hurt it, you just won't get the maximum benefit. There may be a little swirl as the larger hole of the TB hits the smaller hole of the manifold, but effect should be minimum.
Somewher there is a thread about boring the intake while on the car. It involves stuffing the hole in the intake with rags to hold the shavings, etc. Not sure where it is located, however, since I had no interest at the time.
Old Aug 24, 2007 | 10:22 AM
mack's Avatar
I always thought stock was 52 mm also, but I used a caliper and it was only 50mm. Funny thing is my 52 mm TB measured 50mm too. I've seen the thread you speak of about boring the TB on the car. Not to kean about that idea, but I'm not going to take the intake off now. The part that pisses me off is this was supposed to have already been done and I paid for it to be done. I guess I'll go ahead and see how it acts with the new one. If it's not good, I'll just swap it out.
Thanks
Old Aug 24, 2007 | 10:46 AM
FAD2BLK93's Avatar
I thought the stock size was 48mm
Old Aug 24, 2007 | 12:38 PM
plaf713's Avatar
stock is 48mm
Old Aug 24, 2007 | 12:46 PM
thesoundandthefury's Avatar
The bores on the throttle body are 48mm, but the holes in the intake manifold itself are 52mm.
Old Aug 24, 2007 | 12:50 PM
383lt1impala's Avatar
YUP THATS TRUE
Old Aug 24, 2007 | 01:36 PM
radioren's Avatar
Heres the article about boring it on the car.
http://www.bfranker.badz28.com/96ss/58porting.htm
