1st time 1/4 time
Old Aug 25, 2007 | 02:26 PM
C5042081's Avatar
Default 1st time 1/4 time
Well would have like to hit 13's but guess its not too bad considering it was my first time at any track and with 2.73's in the rear.
1st run 14.20 @99mph
2.134 60'
2nd run 14.32 @98.10 mph
2.174 60'
I am thinking a nice set of LT and a fat stall...soon..........
Old Aug 25, 2007 | 03:19 PM
Jon94Z's Avatar
Those are some decent times considering you have 2.73's.
Old Aug 25, 2007 | 03:47 PM
LT1Falcon's Avatar
actually, with those mods i think you should be a little better than that. definitly get some better gears
Old Aug 25, 2007 | 03:52 PM
C5042081's Avatar
I have a set of 3.73's on my list,
I am pretty sure i have a bad egr valve or bad 02 sensor also , so this may have hurt it, also i never raced before ever, reaction time was .796 and crapy 60' time also
It was very humid at the track and quite warm , my second run i ran against my brother, 02ss A4 I matched his 1/8 mile time but he beat me by .5 in the end 14.3 vs 13.8
Old Aug 25, 2007 | 03:55 PM
LT1Falcon's Avatar
actually the 02 doesnt have any effect at WOT and the egr shouldnt matter either if it is stuck closed
Old Aug 25, 2007 | 03:57 PM
C5042081's Avatar
maybe a clogged cat then , my car stinks like gas when running now , nothing is leaking either
Old Aug 25, 2007 | 04:55 PM
LT1Falcon's Avatar
well if the 02 is bad it could be causing that at idle and cruising, just not at WOT
Old Aug 25, 2007 | 05:39 PM
C5042081's Avatar
yup i was thinking the same thing
Old Aug 25, 2007 | 07:43 PM
Schweet97Z's Avatar
i think those times are about right.
Old Aug 25, 2007 | 07:47 PM
LT1Falcon's Avatar
no offense, but i dont know how you can say that. i thought most stock, good running, f body cars run low to mid 14's... 100% stock.
hes got a few mods, ide say you should be able to hit at least high 13's. get some LT's, that should help a lot with your setup
Old Aug 25, 2007 | 07:57 PM
slick1851's Avatar
2.134 60'
2.174 60'
Get into the 2.0/1.9 or lower
You already there, its just the launch bud
My freind was cutting 1.9s 1st time out and on allseaons, with hardly any prep! Just work on the launch
Old Aug 25, 2007 | 08:11 PM
Schweet97Z's Avatar
I ran a 14.0 @ 99 with Longtubes,ORY, SLP Loudmouth at the time, CAI, Wires, Plugs, and Tuned. You cant compare a 2:73 geared auto car to a 6 speed 3:42 geared car. It also does consist on tracks, altitude, track prep, 60ft times and driver. But i could not for the life of me break 14.0 on street tires. Now a nice sticky tire, would drop the 60's which would then increase the ET.
Old Aug 25, 2007 | 09:12 PM
LT1Falcon's Avatar
true true. still i think he could break into the 13's. try again another night. a little practice always helps even with an a4.
Old Aug 25, 2007 | 09:26 PM
C5042081's Avatar
I will def be going back to better my times, I am sure i can get a better time as she sits, As soon as i get this problem solved I will run again
Old Aug 26, 2007 | 12:26 AM
infinitebird's Avatar
A bad o2 can affect WOT negatively if it is detecting a false lean condition, because it will sometimes keep the erroneous correction around during WOT operation.
Old Aug 26, 2007 | 12:36 AM
donkey mule's Avatar
Not bad for 1st time out with the car. I hated my 2.73's, the 3.73's realy woke the car up.
Old Aug 26, 2007 | 03:13 AM
the_merv's Avatar
Gears..
Old Aug 26, 2007 | 04:28 AM
Formula350's Avatar
Most of those times for low 14s I'm sure are with 3.23+ gears. He doesn't really have any power adding mods. So keeping that in mind and this is his first time ever (not the best 60'), I think that's right on.
Old Aug 26, 2007 | 07:45 AM
LT1Falcon's Avatar
hes got more power adding mods than you
Old Aug 26, 2007 | 07:48 AM
LT1Falcon's Avatar
that came out the wrong way. im not putting you or your car down, im just saying he does have power mods (cai, borla, LT4 km, 160*)
