Pushrods?
Old Aug 29, 2007 | 01:10 PM
95N20FORMULA's Avatar
Default Pushrods?
Will these pushrods work for my 95 Formy with a cc305 cam
http://cgi.ebay.com/ebaymotors/COMP-...spagenameZWDVW
Old Aug 29, 2007 | 03:08 PM
97lt1ss's Avatar
that is what i purchased for my 306 swap... as far as i know they are designed for the high energy camshafts... they should work just fine. the only major difference i could find is that the tips are welded rather than being solid.
Old Aug 29, 2007 | 03:13 PM
Bersaglieri's Avatar
What is the rest of your valvetrain setup? I wouldnt have a problem using those with a stock camshaft and low rev's, but going aftermarket I'd much rather see people using one peice pushrods. They are only $20-30 more, so why not?
-Dustin-
Old Aug 29, 2007 | 11:46 PM
alconk's Avatar
Originally Posted by Bersaglieri
name??
-Dustin-
What is the rest of your valvetrain setup? I wouldnt have a problem using those with a stock camshaft and low rev's, but going aftermarket I'd much rather see people using one peice pushrods. They are only $20-30 more, so why not?Where can you get the one piece pushrods at?? I actually slightly bent one because I had the rockers to loose and the rocker turned on me and bent it. In desperate need to finish my hot cam kit I worked the pushrod in the vise until straight. I now want to replace them immediately!! Do you have a part # and company name??
Old Aug 30, 2007 | 12:27 AM
ZONES89RS's Avatar
In-Zane Moderator
Hell, i have used stock pushrods with guide plates on a flat tappet, but not a roller, those should be fine.
Old Aug 30, 2007 | 07:09 AM
If your on a budget you can get trickflow ones, its a Summit Racing brand but maybe some of the supporting vendors sell them. Just dont mix and match, if you have other stocker you were using, pull them and replace. Although the Hotcam kit uses self aligning rockers, depending on how high you want to rev I'd go with one peicers.
-Dustin-
Old Aug 30, 2007 | 06:35 PM
ill be shifting at about 6100?
