Poly mounts on a daily driver
Most should be the same, or useable. Only ones I see a problem with are the sway bar frame mounts since the MM Diameter might be bigger/smaller between the two. I think my 91 had 33mm or 35mm up front, not sure what 93+ has for FE2. Also the tranny mount is almost a must. Ive torn 2 rubbers in less than 8 months. I bought one and it comes with a small warrenty...so i figured ill run it till warrenty dies, then get a poly one like what was on my 3rd gen. In the 3rd gen there was no new vibrations
so It might as well be pointless for me.I tried the poly motor mounts and I did not like the vibrations at all. I took them out and put the new rubber ones on and things are a lot better. I am overly super sensitive I reckon.
Yea, my 89 has that problem.
