This is seriously becoming a bitch....!
My car has been running hotter than what it should and has been using some water, but its not in the oil. I did have a coolant hose that was leaking a few weeks back but is now fixed, so that can't be the issue. It leaks no water on the ground and I can't smell any burning on hot engine parts. I would like to think that the TH-350 tranny with the stall/gear is causing the extra heat build up due to it running at higher RPM's than a stock car, but I don't know?
I have an electric water pump and a 160 stat. But when its hot outside, like 90 degrees or more hot, my car runs at like 200-210. But at night and on cooler days it runs around 180 or less? It never had this problem before and I was wondering what else it could be?
-A bad radiator cap?
-Fans not kicking on?
-The fact that my coolant is no longer coolant but pretty much all water due to the previous coolant leak?
-Or the more heat generated by the engine from the higher RPM?
This is really starting burn my *** b/c I can't seem to figure it out. It never gets hot enough to melt anything down, just hot enough to the point that it pisses me off. A few of my buddies have a EWP and theirs live around 180* no matter what the outside temp is? But then one has a 6-speed and the other is A4.
I don't know? Anyone have any ideas before I go and buy a bunch of **** that I don't need?
Install trans cooler for your upgraded stall.
Replace antifreeze to 50/50 solution.
Replace radiator cap, just to be sure.
Reprogram PCM to have fans turn on at 180*.
To answer a few more questions, my cooler is mounted on the top lefthand side of the a/c condensor. My A/c Is not working at the moment so I never turn it on.
Mine is hard pressed to get over 160 normaly and Barely gets to 180. On an all out N2O passes it hits 200 and is back to 180 by the time I get my time slip.
I am running a Be Cool Radiator.
NBTW also running a Half fill of rock in the block
I had a heating problem with my Stroker..it was getting hot, I set both Fans to come on Manually, I haven't had a problem since, runs at 180*-190* Street, and doesn't get above 200* rompin on it, and we have been in the 105*+Temp range during the day lately. Night time it runs cool..really cool.
I'm trying to figure out the best Slicks for it..it's got alot of power to put to the ground..
