Changing serpentine belt on lt1
Old Sep 7, 2007 | 02:21 PM
TrammelZ28's Avatar
Default Changing serpentine belt on lt1
does anyone know where i could find a how to or anything like that to change a serpentine belt on a 95 Z28, i just dont want to take a bunch of stuff off to get to it if i dont have to. thanks guys
Old Sep 7, 2007 | 02:35 PM
Razor_Blade's Avatar
You should be able to do it without taking anything off. You just have to get under the car to do it. There should be a sticker under the hood that shows how to route the belt.
Old Sep 7, 2007 | 02:36 PM
Dragframe's Avatar
yeah... jsut lay on your damn back and grab the tensioner with a rathet and pull.... grab belt and let go of tensioner.... easy....may help to have a friend.
Old Sep 7, 2007 | 02:49 PM
TrammelZ28's Avatar
k thanks guys
Old Sep 7, 2007 | 05:50 PM
jester1614's Avatar
13 mm bolt on the tensioner
Old Sep 7, 2007 | 05:52 PM
ThoR294's Avatar
its cake
Old Sep 7, 2007 | 06:01 PM
TrammelZ28's Avatar
just wanted to make sure, nothing else has been cake on it lol
Old Sep 7, 2007 | 06:17 PM
Speed Density's Avatar
hashtagBMW
Or 1/2in
Old Sep 8, 2007 | 03:19 PM
Irish350's Avatar
i vote 1/2" boxed wrench
Old Sep 8, 2007 | 06:50 PM
Zralou's Avatar
GM vehicles use metric sizes.
Sara Lou
Old Sep 8, 2007 | 07:10 PM
hashtagBMW
Sara Lou
My toolbox says different
Its a mix either way.
Old Sep 8, 2007 | 08:05 PM
Dragframe's Avatar
Sara Lou
i have never had on gm car that just had metric bolts and nuts on it.. that is dumb to say...
yes... gm generaly sticks to 8, 10, 13, 15, and 18 mm on most of the stuff... but a lot of things on the car (mostly seems on the motor) are standard.
but then again there is a varience from one brand of tool to the next. I say this because if any of you use cornwell end wrench's they have some weird design on the open end and sometimes i just barely can't get em to fit and have to use a different size.
Old Sep 9, 2007 | 02:53 PM
TrammelZ28's Avatar
i used 1/2 and it worked just fine, sucked not having a jack but it was pretty easy to change
Old Sep 9, 2007 | 03:49 PM
C5042081's Avatar
15mm did mine yesterday
Old Sep 9, 2007 | 04:24 PM
transam5.7lt1's Avatar
Once you lose the tensioner, have a friend or somebody else pull the belt at the alternator pulley, its much easier than to get it off at the tensioner, since the ratchet, socket and your hand are on the way. It goes back on in the same order.
Old Sep 9, 2007 | 05:40 PM
camar0corey's Avatar
Yep, believe it or not it is simple! I know its shocking. My car sits at stock height, I can change it out without lifting the car up, by myself with the underdrive pulley. Now that is fun usually takes a extra shot or two at it to get it right. I can't wait to go to a one piece underdrive/balancer.
Old Sep 9, 2007 | 08:25 PM
96mikez28's Avatar
It's a lot easier if you have a 2nd person to loop the new one around the alternator while your below
Old Sep 10, 2007 | 07:28 PM
Firebat's Avatar
I always put the belt around the power steering pulley last. I don't remember if I can get to the belt from the top on a 4th gen f-body but I can on my thirdgen.
