very slow lt1 promblems 17+ in the 1/4
my car goings perfect except it has no power any more well then i guess it doesnt run perfct then but i dont know whats doing this . so when i take off from a start it has no torque at all some times i can stomp on it and it wont move but as soon as it starts moving it feels storng again. i thought it wasnt getting enough fuel but now i dont think that is it because when it starts going it doesnt heicup or anything
give me your opinons please.
i just got heads and new valetrain, underdrive pulleys, msd plug wires 1.6 RR, and some more stuff i havent put on yet i just dont want to put it on and be disappointed
i put it on a scan tool from gm and the fuel pressure is good the injectors are good. i just put new fuel pump and filter in it and i thought mybe it was the plugs so i put ngk's in it. nothing help thanks for the input any other ideas.
list of stuff i have done, new map and maf sensor, fuel filter, k&n cai, air foil, plugs,
i have a aero fuel pressure reg. i havent put in yet mybe ill try to put that in.
The car is a dog off the line it feels as if there is no breathing in the motor. It runs fine around town and no misfire. It is bone stock manifolds cats and all. He has LT's and heads and a cam for it but we would like to fix the low power problem before trying to add performance parts to it.
when we ran it last best time was a 16.0 @94 or so MPH with a blazing 3.0 60'
something funny is wrong..
Just a tip....check to see if the cat is clogged b/c I had an issue kinda like yours with my old camaro. It was slow off the line but at higher rpm it would start to pull....turned out to be a clogged cat didn't figure it out till it would die when I gave it gas off idle. Just an idea, never hurts to try it ya know. Cars can be very tricky at times. Also timing could be off as well (maybe a streched chain or opti out of adjustment) Good Luck
Hope you get it straightened out soon, I'd hate to have alot of goodies sitten around and can't even put them on a car b/c it's not running up to par. Just seems pointless till you get it straightened out huh! Good Luck and keep us posted.
1 Post
check your new MAP and MAF. Something could be faulty and throwing an incorrect load rating to the ECU, resulting in an incorrect A/F calculation to give it more power under a heavy load. then, once you get going, the proper ratio is restored, equaling in high trap speeds.
since you just replaced heads/valetrain, it would be a bad/burnt valve. but check for maybe a bad piston ring, resulting in low compression. from the initial launch, the car is under significantly more stress than when it gets going up top. therefore, the lack of power due to the low compression would be more noticeable at low speeds.
good luck with the problem, and check back and let us know how everything turns out!
the MAP will not do anything, the MAP on the 94+ LT1s were just there for diag purposes. The MAF will **** it up bad. If it has top end power, then I would not think it would be a cat clogged. if the cat was clogged. it prolly could not go over ~40mph
