Lil Help
Old Sep 9, 2007 | 04:53 PM
SSrollin22s's Avatar
Default Lil Help
Im new to this site and i need a little help with my 94 Impala SS. Im having some work done now i put a comp cam in, intake port to 58 mm, 58mm throttle body, 30lb injectors, comp lifters, msd 6al, cap and coil, underdrive pulleys, and now working on the heads. I want to have the heads ported and shaved. I need to know if im headed the right direction or messing up, i also want to change rocker arms, valve springs, and push rods. What set up should i go with on that. I would appreciate any advice you guys could help me with!
Old Sep 10, 2007 | 07:58 PM
can anybody out there help me out???????
Old Sep 10, 2007 | 09:55 PM
MEAN LT1's Avatar
What are your intensions for the car? street/strip?, is it a daily driver?.
Old Sep 11, 2007 | 07:42 PM
just a weekend car but i want street power no strip cause i got it on staggerd 22" rims. I want to get 400hp 2 the rear wheels or close 2 it?
Old Sep 11, 2007 | 07:44 PM
97bagds10's Avatar
well get some long tube headers and a stall, and since you have 22's i would get a 4.10 rear end. other that this with what you have its on the right track. also nitrous doesnt hurt
Old Sep 11, 2007 | 07:48 PM
i got headers, not long tube and i got a auburn posi wit 4:10 and 4l60e tranny with shift kit. i need a good set up for the heads like what rr and springs to go with.
Old Sep 11, 2007 | 07:50 PM
ThoR294's Avatar
id remove the underdrive pullies... they do more harm than good
Old Sep 11, 2007 | 08:04 PM
97bagds10's Avatar
i went with the lt4 cam setup. comes with 1.6 springs, rocker arms and just about everything you need. its a good street setup.
Old Sep 11, 2007 | 09:01 PM
Irish350's Avatar
id get ahold of lloyd elliot or advanced inductions.. get your hands on some 1.6 RRs, new hardened pushrods and springs thatll handle the lift youll have with that setup (generally those companies will reassemble the heads with springs and retainers, but youll need to do guideplates, rockers and pushrods). a good stage 1 setup should get you to the 400 hp mark
EDIT: id say no go with that lt4 setup.. it does have some decent hardware, but better stuff could be found, and generally cheaper. even if you did get it youd need new springs, as those can barely handle the lift the hotcam has
Old Sep 12, 2007 | 09:04 PM
Good lookin out i think i got i good idea on where i need to go the set up. I'll have some pics for yall soon! Oh, 1 more thing flat black or kandy what you think on tha paint?
Old Sep 12, 2007 | 09:19 PM
97bagds10's Avatar
kandy. flat black is only good with 16" or smaller rims lol
