thinking of going solid roller, anyone else??
Old Sep 11, 2007 | 06:39 PM
MEAN LT1's Avatar
Originally Posted by Irocss85
this part. did you mean, if you drive more miles then he says, then youd recomend HR, but if 3500 or less miles go SR? thats what I think you mean.
I think what Pepe was getting to was that the original poster drives his car too much for a SR. In other words if the application is a daily driver then a SR wouldnt be the first choice.
Old Sep 11, 2007 | 07:20 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Originally Posted by zigroid
do you guys with solids all run shaft mount rockers?
I'd like to run a mild solid roller but shaft mounts just aren't in my budget. will running just plain old comp pro mag rockers eliminate the benefits of running a solid? my old hydraulic only lasted 3,000 miles and I adjusted the valves 4 times (stupid comp Rs!) I don't have anything against adjusting valves haha. I want to run well into the 11s with stock heads and then see what I can do with a set of heads. trying spend money on a budget but smartly.
I'm not sure if those comps are adjustable, but you'll need an adjustable rocker to set the valve lash. I'm starting off hydraulic then when I get some more money be switching the whole top end over. I've just got to get used to the extra 200+ horsepower first.
1800th post!
Old Sep 11, 2007 | 07:40 PM
redneck01's Avatar
im going a solid route for bracket racing next year. good valvetrains dont have to be adjusted hardly ever, depending upon how they are setup initially and played with.
SR is the way to go for anything more than daily driver
Old Sep 11, 2007 | 09:03 PM
zboner's Avatar
yea i dont think he understood me, its not my daily, i want a race car i can drive to the track and home, this year i only put 500 miles on my car... so 3,000 was just a wild guess and that was max miles
Old Sep 11, 2007 | 09:05 PM
zigroid's Avatar
1800th post!
comp pro mags are adjustable
Old Sep 12, 2007 | 12:16 PM
fast's Avatar
I have a small comp SR and all comp valvetrain and am having no issues using the same pro mag rockers that so many use
these guys have given the best advice you can get . . . from the experienced . . . don't be scared of solids
Old Sep 12, 2007 | 12:32 PM
NJLT1SS's Avatar
Well this winter I am swapping intakes (going from a welded/epoxied/ported LT4 intake to a sheetmetal) and swapping cams. My engine builder was throwing the idea at me to go to a solid, as he said that I would gain on average 15 to 20 HP all over the powerband, and then more in the uppers. My only concern is driving around here in North NJ, is the occasional stop and go traffic. I only put about 3K miles a year on the car. Now this thread has me thinkin.......
Nick
Old Sep 12, 2007 | 02:16 PM
-PEPE-'s Avatar
oh that, well yeah I guess I mean I'm no expert, just think a low mileage driven car would fair better with a HR. BUT that being said I don't drive mine that much either and run a SR, I drive to McDonald's and even the track, so I guess that would be cool. Especially after reading that he wants a racecar and would like to drive it to the track, SR for the win.
Now if this was an everyday driver to get you to work, may be a different story. I do drive mine to work every other day when the drag tires aren't flat lol.
Old Sep 12, 2007 | 05:53 PM
Irocss85's Avatar
yeah thats what sucks about et streets. had to get dad ET street radials cause he only drives his car once in a while, and it sucked for him to have to fill up the F'n tires everytime he wanted to pull it out of the garage.
Old Sep 12, 2007 | 08:39 PM
95 Formula's Avatar
Originally Posted by FASTFATBOY
He He, yeh pull up next to me with your hydraulic roller.
David
uh..read my sig dufus..lol. I've been solid for 6 years now.
Old Sep 12, 2007 | 08:43 PM
95 Formula's Avatar
Originally Posted by MEAN LT1
I would have never thought I would hear such a thing from you. Unless you were just kidding. IDK
I was just picking guys. I'm just so tired of the people who have never had a solid roller in their car talk about how much of a pain in the *** they are to maintain. I'm a big proponant of a solid roller setup if your building your car to go fast and now just put put around on the street. If your trying to build HP...its the way to go. If you want a car that you pay someone to build for you and never want to turn a wrench on it..stay away from them. I'm not saying they are hard to do but you have to want the benefits of a solid setup to put up with what I consider a small amount of maintenance.
Old Sep 12, 2007 | 08:45 PM
  #32
95 Formula's Avatar
I ran comp pro mags on my solid setup for about 5 years and went 10s all motor on them taking it to 7000 rpms. I upgraded to Jessel shaft mounts when I changed my head setup to lt4s.
Old Sep 12, 2007 | 09:04 PM
  #33
FASTFATBOY's Avatar
DUHHH!!
I was referring to those guys that were afraid of a solid roller and were leaning towards a hydraulic roller.
David
Old Sep 13, 2007 | 12:19 PM
  #34
95 Formula's Avatar
My bad..was wondering why you would be saying that to me when you know I've been running a solid roller for so long.
Old Sep 14, 2007 | 10:34 AM
  #35
zboner's Avatar
great guys thanks for all the input on here.
