Bad vibration
Old Sep 11, 2007 | 07:38 PM
My94TransAm's Avatar
Default Bad vibration
I have a bad vibration at 85mph and up. I thought it was the alignment/balance, but nope. I thought it was the u-joints, but nope. I thought it was the tire pressure, but nope. Any suggestions?
Old Sep 11, 2007 | 07:44 PM
ThoR294's Avatar
where does it feel like its comin from
Old Sep 11, 2007 | 09:14 PM
1slowZinthe513's Avatar
pretty sure its the drive shaft..lots of lt1s have had that problem.. get an aluminum one for about 100 bucks on here
Old Sep 11, 2007 | 10:44 PM
ThoR294's Avatar
try putting it in neutral and seeing what happens
Old Sep 12, 2007 | 04:15 AM
Ralls's Avatar
The lt1 drive shaft is known to be out of balance. I believe there is a TSB on it. An ls1 drive shaft should cure it.
Old Sep 12, 2007 | 08:56 AM
great421's Avatar
Although I agree that it is probably the DS, don't forget either the DS mount (that was my car's problem) or out of round (not out of balance) tires.
Old Sep 12, 2007 | 02:45 PM
I just put a LS1 DS in it and it is still doing it? I feel it mostly in the seat and the pedal, but not so much in teh stearing wheel.
Old Sep 12, 2007 | 02:59 PM
Ralls's Avatar
Did you actually get an alignment done? You said that's not the problem, but what did you do. Ball joints could be shot. Wheels/Tires out of balance
