12's possible
Old Sep 11, 2007 | 07:58 PM
cruzin94's Avatar
Default 12's possible
i have a 94 z28 and i have the mods in my sig then im also gettin 3.73's installed (i have 2.73's right now) what do u think ill be able to run with good street tires....then pretty soon im gettin a 3500? stall and if i can get it to hook do u think 12's are possible
Old Sep 11, 2007 | 08:09 PM
97bagds10's Avatar
i would get some headers, cam kit and a good tune before i got that big of a stall. and with gears and what you have i dont think it will get 12's... i have a cai, TB, stall, headers, full 3" exhaust, cam, and lacking a tune i still run 14's... but after i put the 3.73's and get it tuned right it will drop the time significantly
Old Sep 11, 2007 | 08:13 PM
Revelation Z28's Avatar
some DRs and the gears and the stall and a tune with a good launch will get you a 12.9-12.8.
i need a tune and i will be in the 12s on street tires. my suspension helped big time.
Old Sep 11, 2007 | 08:14 PM
PewterScreaminMach's Avatar
My brother had a 94 TA A4 with full bolt-ons, including a full exhaust and cutout, and a small cam and did a best of 12.8, no stall. He definitely also had drag radials and gears, although I don't know if they were 3.42s or 3.73s.
Old Sep 11, 2007 | 08:37 PM
97bagds10's Avatar
didnt see you had headers. a good cam and a tune does alot for these motors. add those to your list and it will be for sure in the 12's.
Old Sep 11, 2007 | 08:38 PM
Puck's Avatar
With a stall he would have ran that time without the cam .
A bolt on LT1 should run 12's IMO. At least outside of very thin air - I am spoiled by low to negative DA...
Old Sep 11, 2007 | 08:41 PM
C5042081's Avatar
i think with gears and a stall you should be running 12's as long as it hooks
Old Sep 11, 2007 | 08:51 PM
burnzilla's Avatar
Say goodbye to your aftermarket gears with a stall if you track alot.
Old Sep 11, 2007 | 08:53 PM
Yeah, Lebanon Valley isn't the best track, and his cam was for a blower that never ended up going on, so it wasn't the most economical setup in terms of power, but the stall would have helped.
Old Sep 11, 2007 | 08:55 PM
1slowZinthe513's Avatar
my z ran a best of 13.3 with full bolt-ons and headers with stock gears and converter stock suspension.. i would say all he needs is a converter and hes in the 12's
Old Sep 11, 2007 | 08:58 PM
fast's Avatar
I ran a 12.96 w/ MAC shorties an nitto drag radials with the stock converter and 3.23s so yes 12s are very possible
but as mentioned the DA and weather are the biggest factor and of course impossible to control
good luck to ya!
Old Sep 11, 2007 | 09:05 PM
transam5.7lt1's Avatar
I kind of see it hard to hit 12's with those mods, you might need a little more than that. It also depends on the altitude and climate where you make the run.
Old Sep 11, 2007 | 09:20 PM
urbanhunter44's Avatar
Headers, stall, gears and tires is an EASY recipe for 12s
Old Sep 11, 2007 | 09:51 PM
people are still suggesting he gets headers along with stall gears cam etc. he already has pacesetter LT's if you look at his signature..
Old Sep 12, 2007 | 12:03 AM
BizZzatch350's Avatar
Moderator
For one, you don't need a cam to get in to the 12s. I ran 12.8s with no front sway bar, cold air, Hooker LTs, ORYP, Borla and a Vigi 3200. Thats on heavy *** WS6 wheels and worn out Nittos cutting a 1.72. I still have the stock 3.23s as well. Looking at your sig, your closer to the 12s than you think, your car isnt hooking for **** man, bring that sixty down as it is and you have a bottom 13 second car. A stall and gears will set you deep in the 12s but its all worthless unless your on a good tire.
Old Sep 12, 2007 | 02:55 PM
My94TransAm's Avatar
I think with the stall, gears, and DRs you will be there. You are going to see a huge difference with the 3:73 gears and the stall. You are going to be pissed that you have been driving around with 2:73 lol.
Old Sep 12, 2007 | 03:35 PM
Formula96's Avatar
little bit of n20............
Old Sep 12, 2007 | 05:17 PM
also if you dont plan on upgrading the 10 bolt to a 12, you can hang a set of brass ***** off of the housing cover since GM never gave the 7.5" its set of them. especially since you'll have sticky tires and 3.73s and a stall, its gonna need them.
Old Sep 12, 2007 | 09:06 PM
But it is an A4, it should hold up...well as long as he doesnt use MT radials.
Old Sep 12, 2007 | 09:10 PM
burnzilla's Avatar
You ever ride in a stalled car?
If he tracks it alot, the gears won't last long with a stall and traction.
