Need help wont rev past 4 grand
Alright, i've been knocking this out in hope that it wouldn't be the opti but it's pointing to that direction, my last hopes is that it's this. . . .tonight i went and had my codes checked to see if anything was up - I have a bad MAF I've got an extra one out at my shop that's good and I can put into tonight. . .BUT the thing is - if it isn't reving past 4 grand would the MAF have any effect on that or would it still possibly be weak opti? I've changed plugs the next thing is plug wires and the opti. . .but when i changed the plugs it ran great for 2-3 days with no problems of reving past 4 grand it just started happening again today. . . .car smells like it runs a little rich too. . . .thanks!
Oh and this is on the formula.
Originally Posted by tylert14
Don't forget little things, whens the last time the fuel filter was changed. Is your fuel pressure good?
That's a good point. . . .although my fuel pressure has been very good it feels like i'm almost hitting a rev limiter though ontop of that i was on a drive home from a 5 hour trip from austin when i first discovered the issue and after about 3 hours of 15 RPM road crusing when i went to pass someone it wouldn't rev past three grand i thought i wasn't going to make it the rest of the trip. . .
*edit* just went out to the shop got the other MAF still doing the same stuff . . . it starvs for power at 3-4 grand It's probably the opti ._. or the fuel. . .but i really dont think it's that. Although for 15 bucks it aint a bad idea to change that out. . . .i dont think the fuel pump is going bad though seeing as i get plenty of fuel. . .the filter is a good plan though regardless i do live in west texas. . .dirt is evil around here.
My converters should be gutted. . .they arn't glowing i've checked there - there's one still on the manifold i might look into again but man. . .aside from that not really. - I'll take it into my dads buddy to see what he has to say I've got two of em on there one i know is gutted because it went bad. . .the other one sounded hallow.
It sounds like I've got a small exhaust leak somewhere though. . .but i mean my camaros had that issue before and it was never this bad.
1 Post
that exhaust leak is most likely why your converter went bad.i bet the leak was somwhere on the manifolds which btw will send the 02's false readings.you do have a cat on the drivers side and i bet its not gutted.
The bolts on that side are so rusted i cannot pull it off but what i'll try and do is cut the pipe at the bottom check to see if it's gutted then replace the manifold gaskets. . .that's the best i can come up with??
Gunna go to the muffler shop this week to have them cut off the rusted bolts on the fitting and make me a pipe that just goes directly in place of the converter with a fitting welded to it. . . . .
