lt1edit or dynotune?
Old Sep 20, 2007 | 07:00 PM
TrammelZ28's Avatar
Default lt1edit or dynotune?
which one would be better?
Old Sep 20, 2007 | 07:31 PM
96capricemgr's Avatar
Tunercat IF YOU KNOW HOW TO USE IT or are willing to learn.
Old Sep 20, 2007 | 08:28 PM
infinitebird's Avatar
well it's not really one or the other. A dynotune would still need to use something like lt1edit or tunercat to actually do the tune.
Old Sep 20, 2007 | 08:33 PM
TrammelZ28's Avatar
ya i am talking about what would be better in the long run price wise
Old Sep 20, 2007 | 08:55 PM
Rowdy94's Avatar
It depends if you can learn to properly use a wideband O2 to tune your car. There is a large learning curve associated with tuning your own ****. If you get it dynotuned, it should be a pretty damn good tune, and cheaper that way if you never plan on doing anymore mods.
Old Sep 20, 2007 | 08:58 PM
Depends on who does the dyno tune, some tuners know what actually works on the track and others shoot for max on dyno numbers, not the same thing. A good tuner can use the dyno to his advantage, but understands the rollers are not the end goal.
Old Sep 21, 2007 | 06:04 AM
jasonisdn's Avatar
perfectly stated. also a dyno jet and most mustang dynos , are used to tune WOT only. I don't see you riding around at 100% throttle all day long. A wise man told me to look for either a Dyna pack dyno or a mustang dyno with a eddy brake. Makes tuning faster and easier. i would go with tuner cat and a dual wideband setup. good luck to ya
Old Sep 21, 2007 | 06:07 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Exp of the user is a key ingrediant here which seems to me you do not have, and unless you pay someone to do ti for your, your not really saving. In my case I bought Tuner CATS which btw is really cheap compared to EDIT and I paid the normal per hour of dyno time, you need a dyno (with apprioriate sensors such as FP, and A/F) to verify results
