Head light prob
Old Sep 26, 2007 | 11:34 PM
DBEST369's Avatar
Default Head light prob
My headlights come up but when i go to turn them off they both go down but then the passenger side comes back up n stays like that. any ideas?
Old Sep 26, 2007 | 11:39 PM
Formula_LT1's Avatar
Thats weird as Hell? I know you can put it back down manualy with the little screw on the HL motor.
Sounds like a short or a grounded out wire? IDK?
Old Sep 27, 2007 | 02:17 PM
DBEST369's Avatar
ya it is weird. i had my friend unplug the motor when i flipped my lights off so it 's down right now but it just pisses me off. i think im just gunna go to my V6 firebird n take the whole assembly off of that but im just too lazy
Old Sep 27, 2007 | 07:51 PM
ExtinctBird's Avatar
When my headlight motor gear broke (common problem), it also broke off one of the plastic ***** that acts as the stop for the headlight mechanism. You should be able to see these ***** that limit the travel of the lifting arms by lifting the hood and looking down between the headlight motors and the headlights.
I ended up fabricating a new replacement metal stop that I bolted into place using the existing motor bolts. Like I said, this happened at the same time that my headlight motor gear stripped, so I also had to order a new brass gear to fix the motor.
Old Sep 28, 2007 | 09:56 AM
DBEST369's Avatar
ya i dont see the **** on that side n the other side is fine but it makes this weird *** grinding noise. like the motor is still spinnin you know how i can stop that?
Old Sep 28, 2007 | 07:44 PM
The grinding noise is the unmistakable sound of a broken headlight motor gear. You need to take out the motor and take it apart to confirm, then order a new brass gear kit. There is a sticky here somewhere with the description of this problem.
Old Sep 29, 2007 | 07:21 PM
Zralou's Avatar
When the motor gear wears it has been know to make the headlights do all sorts of strange and wonderful things, including what you describe.
Before pulling it apart, try the 180* trick...
Pull off the actuator arm, rotate the motor 180* with the manual ****, then reinstall the actuator arm. I did it on mine over 2 years ago and its still going strong.
Sara Lou
Old Sep 30, 2007 | 08:36 PM
DBEST369's Avatar
haha that what i do to put it down but then it still comes back up n it pisses me off so now i dont drive at night n if i do i only use my foglights
Old Nov 14, 2007 | 01:40 AM
DBEST369's Avatar
ok the 180 trick it is
