Silly idea...
Old Oct 8, 2007 | 11:25 PM
Formula350's Avatar
Default Silly idea...
If someone was to run a DIS and dry sump oil system, could they use an LS1 cam? Not that I plan to, but the idea just popped into my head as to why the LS1 cam doesn't work in our motors: no oil drive gear.
Yea, I know
Old Oct 8, 2007 | 11:37 PM
Revelation Z28's Avatar
weld on a dowel pin for the opti too. for pre 95 cars.
Old Oct 8, 2007 | 11:39 PM
cherryelky305's Avatar
Different firing order? They are not the same.
Old Oct 8, 2007 | 11:44 PM
thesoundandthefury's Avatar
The reason nobody runs LS1 cams is because the bearing journals are too big: 55mm's for the LSx's vs. 48mm for the Gen I & II stuff. Even if you were able to bore out the cam tunnel to 55mm's to make the LSx cam fit, rotating assembly clearances would become a serious problem. I think if you did you could probably rule out ever running anything bigger than a 3.48 stroke crank.
All the other issues: firing order, distributor drive, etc. are secondary concerns but could be worked around.
man with the composite intake coming out, i wish i could change the firing order and everything to fool people.
who votes group purchase to ban formula350 from the LT1 section
Old Oct 9, 2007 | 07:15 AM
Z28_DAD's Avatar
cam length is different too
Old Oct 9, 2007 | 08:39 AM
dhdenney's Avatar
Yeah the LS1 cam is short. I could have took some pics side by side til I sold the LT1 cam I had.
