Weird Noise from engine. Possibly lifters?
Old Oct 14, 2007 | 12:58 AM
1bdbrd's Avatar
Default Weird Noise from engine. Possibly lifters?
Ok, so my car has been starting now just fine for almost a month but there is a weird ticking noise coming from inside engine it sounds like. It only happens after you have cranked it over or ran it for any length of time. The noise sounds like how the exhaust sounds as it cools but its not that because even if the engine doesn't start it will still make the noise.
I was thinking it was lifters bleeding down but after talking to a friend of mine I am not so sure about that..What could it possibly be? Mods list is in the sig.
Old Oct 14, 2007 | 09:56 AM
TripleWhite96's Avatar
mine has started to do that..when I let it sit or on cold starts..it'll sound like lifters ticking..but then when normal temperatures the noise goes away..same for you?
Old Oct 14, 2007 | 10:17 AM
dhdenney's Avatar
Possible piston slap for you? To the OP, I have no idea.
Old Oct 14, 2007 | 12:30 PM
1bdbrd's Avatar
Im not sure what happens when it gets up to temp. I havent driven the car yet, just let it idle on the jack stands. But the noise happens for a good few minutes after i shut the engine off or stop cranking it.
Old Oct 14, 2007 | 01:01 PM
DBEST369's Avatar
i think mine does that **** too like tuik tuik tuiktuitktuitk? haha its kinda hard to make the noise
Old Oct 14, 2007 | 03:33 PM
mr_wizard's Avatar
I'm assuming you guys checked the oil? It could be lifters, noisy valves, or the rod slapping up against the block. You should probably find out as soon as possible.
Old Oct 14, 2007 | 06:22 PM
weird lol..today I decided to clean the motor..i've had a nasty top end misfire for awhile..no more ticking noises or misfire and the car pulls so much harder..all i did was clean my K&N filter and wash the motor o.O wtf?
Old Oct 14, 2007 | 07:37 PM
frack's Avatar
Mine does the same thing, but it sounds to me like it is coming from the y-pipe. I guess it would not hurt to pull the valve covers off and give it a check. I have no clue. I never been one to diagnos by sound. I could not even try describe the sound.
Old Oct 14, 2007 | 08:21 PM
James Montigny's Avatar
Gremlins .... sneaky little bastards ...
Old Oct 14, 2007 | 08:28 PM
transam5.7lt1's Avatar
Isn't that sound normal as the engine is cooling off and oil is draining back to oil pan....
Old Oct 14, 2007 | 08:33 PM
Or water dripping off the AC onto headers
Old Oct 14, 2007 | 08:34 PM
redchevcam's Avatar
sounds like the ol' Gm piston slap
Old Oct 14, 2007 | 10:54 PM
1bdbrd's Avatar
I've never heard of an LT1 with piston slap. But I know for a fact its not piston slap due to the fact that it happens when the engine is OFF. There is nothing moving while its making this noise; atleast not that you can see externally. Its not the engine cooling down because so far I haven't ran it longer than 5 minutes because the cooling system isn't done nor is there a belt on the car so its running off the battery. The oil was changed and looked fine.
Old Oct 16, 2007 | 10:20 PM
frack's Avatar
That is definitely hot oil, dripping back down to the bottom of oil pan. Mine does that I after I shut the car off. Thats normal.
Old Oct 17, 2007 | 05:13 AM
skinnies's Avatar
But he mentioned it happens when cranking it for a length of time, but not running it. It does also happen after he runs it though.
Old Oct 17, 2007 | 09:08 AM
1bdbrd's Avatar
Always got my back.
But yeah, like he said, it couldn't be hot oil because the engine hasn't run longer than 5 minutes at a time. A good majority of the time its just run long enough to maintain an idle (untuned cc306) or to see that any wiring work I did works.
Thanks for the help though guys, keep it coming!
Old Oct 17, 2007 | 06:24 PM
Dragframe's Avatar
not gm... ls1 piston slap. I have never heard any motor have piston slap like the LS1's....
And it wouldn't be that because like everyone else mentioned, it happens when the motor is shut off.
And i haven't a clue WTF could be making that noise if you don't even have to start the motor to get the noise....
Old Oct 17, 2007 | 06:55 PM
krayzie7th's Avatar
haha same thing with me, i run it after i turn it off you can hear a little ticks im sure thats what it is just the lifter noise.
