New Motor, No Start...Help ASAP!!
1 Post
So I know that the big wire goes to the big terminal... No ground is needed because it grounds itself on the block...what terminal do the purple wire and the little black wire go to bc there are two left? And there are two black wires that look EXACTLY-A-FREAKIN-LIKE. One goes to the starter I assume and one is a ground for the ECM I was informed..?. How do i tell them apart?
See if this helps. http://shbox.com/1/starter.jpg
http://shbox.com/1/g103.jpg
Ground from PCM isn't on the starter.
