Grounding Kit = 9HP?
I have a perfect test for you. check the power at your battery. then check your power at the coil. guarantee with stock wiring you will see the same voltage. maybe .01v difference. you wont magically pull volts out of your ***.
... this thread is rediculous...
All of this and more is a bunch of stuff that we try and do to try to get that last tiny amount of horsepower out of the engine. The guys that say that this is bullshit haven't tried and are jumping on the bandwagon for whatever reason.
To the response above about the stock wiring not losing much voltage at the coil. Thats fine and well, I won't argue with that. What I have performed and proven on cars I've had (not my firebird yet) electrical modifications. On most of the stock cars I've had, they usually run 13.5 volts from the factory. I've consistently pull over 14.0 volts, even at idle, after doing the modifications. You can't argue that that will hurt performance in any way. Its just another trick to add to the list of **** we do to pull every possible tick of horsepower.
Make sure you use race muffler bearings and Type 7 (Pink) blinker fluid.
Don't let the sales guy talk you into Type 8, it's a waste of money and actually costs HP.
Airfoil, which he also dynos, helps a it too, but that's common sense when dealing with air flow and turbulence. The donky dong removal has nothing to do with power gains, not that I've ever seen or heard. I'm not even going touch "wrapping the intake". That's the stupidest thing I've heard. Descreening the MAF is a proven waste of time and everyone here recommends against doing it, same with porting since the stock one will flow enough for around 500hp. the IAT is a sound mod, but it has factors that make it worth it or not. If you have a metal CAI that gets heat soaked, then yea relocating it wouldn't be a bad idea, but if you're on stock, or plastic CAI, then there's less of a point in doing it.
http://www.ws6.com/mod-8.htm (TB Coolant Bypass)
http://www.ws6.com/mod-4.htm (Air Foil)
http://www.ws6.com/mod-7.htm (AFPR since people say it's a pointless mod)
http://www.ws6.com/mod-14.htm (Electric water pump)
now... if the path that the electrical current is SUPPOSED to follow, is a much better (easier) path to follow, there would be less chance of stray voltage trying to find its way to ground via the opti circuitry when moisture is present- low-resistance wires, good plugs, no anti-seize on the threads, good block to chassis, and block to battery grounds, etc...
more than anything I agree with the conclusion that the "big 3" mod is probably not going to help a whole lot unless your electrical system is in bad shape. I did it to my truck and noticed a difference in performance... then again, the cable going from the alternator to the battery had corroded in half as well, on top of the power wire to the distribution block being corroded 4 inches down the cable for the battery terminal. so replacing the wire only brought it back up to par with what it was in '94, but it was definately an improvement.
Moistures bad for them, over-reving, well 99% of ya'll out there cant over rev one.
What kills optis MOST of the time, is high secondary resistance. Worn out spark plugs with increased gap. Old plug wires with high resistance. These 2 things cause the high voltage to want to find the PATH OF LEAST RESISTANCE which usually is through the epoxy cap, from one copper trace to another. In extreme cases, it (the high voltage spark) will end up dancing around inside the distributor and zapping the actual opti module.
Keep your plugs changed fairly regularly, and your plug wires in good shape, and your opti will last a long time.
Replacing your battery cables with larger ones WILL NOT DO A DAMN THING IF YOUR ELECTRICAL SYSTEM DOESNT REQUIRE IT.
It wont cause your alternator to put out more volts or amps. It only supplies what the system needs at that time.
It wont make your coil have a higher output. The output of the coil is determined by the secondary resistance.
It wont cause your injectors to squirt more fuel. It wont cause your PCM to make calculations any faster.
I have seen a few instances that increasing wire size let fan motors run faster, and headlights burn brighter. But this was replacing the secondary system wires, not battery cables. And in the case of headlights, theres actually a relay kit made for Imp SSs just to cure dim headlight syndrome.
In that sense, I agree that its not a bad idea to replace wires in the car that you discover have been aged severely due to whatever conditions. However, I dont believe that it will create any power gains. More of a placebo effect if anything.
