AC Delete
I actually just put that one on last weekend. You're still going to need a shorter belt. it does say that it retains the stock belt, but it doesn't. I put a 1" shorter belt on mine and it works great. You could probably get away with a 1/2" shorter if you could find one.
That's exactly what I have. it even has the GM part number on it as well. The belt was just a bit loose for my liking, it actually was loose enough to cause charging problems. So i believe it depends on the life of the belt as well as the brand of the belt if you need a shorter belt.
Mec
:Update--Found one at NAPA for $41!!
