Looking For Stuff To Do To My Car Today...
Would a MSD Blaster Coil Be Good To Put In My Car? I Replaced Mine Last Year With A Crappy One From AutoZone
I Also Wanted To Do A Water Fluch Becuase Its Like Nasty Brown Do I Need To Use The Green Stuff Or Orange ?
I Have A SLP LM 2 On My Car With A High Flow Cat Is There Any other Muffler Or Anything I Can Do To Tone Down The Rasp Without Losing Performance?
I Havent Change My Spark Plugs Ever Since Ive Had The Car They prob. Have About 40K Miles On Them Whens A Good Time To Change Those?
Thanks Guys!! =]
Nasty brown? No oil in there right??? Not sure if your car uses the green or orange,i would GUESS green. And its not water,its coolant
Stay with the LM2.
If you're not FI or spraying and the car has no knock,they should be fine well past 40k.
Regarding the plugs, it probably wouldn't hurt to change them. You can find NGK TR55s at any local DAP. Use a little bit of dielectric grease in the spark plug boots when you put them back on. It will help with conductivity and keeping moisture out.
and switch to orange coolant
i got used tires today they are almost new i never heard of them tho they are called comp bfgs 275/40/17 they were 50 bucks so whatever they seem kinda hard tho
what else can i do to make my car run good and how much do shops charge to chnage my plugs becuase its a pain in the *** i heard and i dont feel like dealing with it
the sparkplugs everyone says is a pain in the *** so id rather just pay someone to do that it has ngks in it so ill go with the same thing
BTW the hell with BBK shorties.
I can't wait to put in the longtubes, maybe it won't be a whole day process to get some new plugs in.Do the plugs yourself, figure your average shop is $40-60 a hour. They don't have superhuman speed over you or anything, so figure on quite a few hours. That time of 6 1/2hr. I stated is the 4th plug change I've done with my current setup, even with the way short slp socket and working around shorties, it completely sucks.
I guess if you have a couple hundred you want to throw at a guy to put your plugs in instead of buying more mods, then go for it. If your in FL I'll come put your plugs in for $200.
so what about the msd blaster coil is it worth it to change will i notice anything?
