Delteq VS Opti
Old Oct 26, 2007 | 08:07 PM
KILLERZ/28's Avatar
Default Delteq VS Opti
well my opti just went out in my car maybe about 800 miles on if that many. I was thinking about putting the delteq system on my car just wanting to hear some reviews from others with this system GOOD and BAD. i also have a 383 in my car is this system good with high HP cars?
Old Oct 26, 2007 | 08:51 PM
383lt4's Avatar
i have the delteq and LOVE it!!! not 1 problem in the 2 years i've had it on the car. ohhh and i wash my engine everytime i wash the car and the delteq has never failed. and my 383 made 402rwhp and 408rwtq with the old cam. it should be a little more with the new cam. i just started it up with the new cam a couple of weeks ago. i will never own another ltx car without the delteq system.
Old Oct 27, 2007 | 10:24 AM
96lt1m6's Avatar
you will need a new opti to go along with the delteq.the set up has had quite a few reviews and people like it,same goes with the LTCC both great products.
i have been looking heavily into the two of these units and really have not decided on the best for my set up.
there is a bunch of reading material for the two,the LTCC seems to be more expandable though....
Old Oct 27, 2007 | 01:18 PM
KILLERZ/28's Avatar
Ya i have heard alot about the LTCC I will have to check them out. thanks
Old Oct 27, 2007 | 03:58 PM
96silverram's Avatar
My vote is for the DELTEQ setup with all the extra's. You will like how responsive the throttle is after the install.
Old Oct 27, 2007 | 05:35 PM
SmokedOutZ28's Avatar
Whats all the extra's? I thought we talked about it before but i cannot remember.
Old Oct 27, 2007 | 06:39 PM
dhdenney's Avatar
He's referring to the DIS-4 ignition (MSD) and the interface modules. Personally, I did not really like the DIS-4, too many wires. I loved the Delteq, but there are several features you don't get with the system unless you add in the DIS-4. That being said, I needed at least a timing retard with the Delteq and finally just went back to the original opti setup. With my new Mallory, I've got the retard, a rev limiter, and even a two step. I did keep the Delteq in case they came out with any upgrades.
Old Oct 27, 2007 | 06:41 PM
dhdenney's Avatar
^^^Hottest car on LS1 Tech.
Old Oct 27, 2007 | 08:09 PM
Smoked out Z28,
You may not want to put up with the additional wiring that is required to run the DIS 4, tach interruptor, coil interfacers & red msd twin towers. It definitely takes a little time to figure out the wiring for a DIS-4 and the Delteq. I also did the GEN II dynatech billet opti (rotor-less upgrade) with the DELTEQ billet cover. I definitely was happy when I finished, but it was a B*tc* to get the wiring correct
Dhdenney,
That has to be one of the best compliments I have ever received. I appreciate the props !
Old Oct 27, 2007 | 08:22 PM
hyperzone's Avatar
I have had the delteq unit for ummm... 3-4 years now. I'm not pushing crazy power or RPM but, it works great and makes wire and plug access a bit more conveniant as well (assuming you dont mind taking that time initially to make custom wires).
Old Oct 28, 2007 | 10:58 AM
96capricemgr's Avatar
It still needs a working opti, and if you can figure out what is wrong to kill a new opti then the opti will survive and you don't need to pretend to bypass it as these kits do.
Old Oct 28, 2007 | 11:27 AM
dhdenney's Avatar
It just eliminates the cap and rotor function as was said ^^^. Some people think it eliminates the whole thing. If you're having problems with cap and rotor and the optical is ok, then the Delteq or LTCC will work.
Old Oct 28, 2007 | 02:46 PM
KILLERZ/28's Avatar
thanks for all the help
