few small problems
Old Oct 29, 2007 | 01:29 PM
daniel6718's Avatar
Default few small problems
cold start my car idles high
cant figure it out...i can drive 5 minutes and it will still ilde at 1500-1800+ at lights...but 5 seconds after i start it if i let the clutch out and bog down the motor 3 or 4 times it will idle down to 100 and stay there just fine...
i removed the t/b and cleaned well...check for vac leaks...but its perfectly fine after it idles down, like it has trouble searching for idle...but it doesnt change just stays at 1500-1800...if i let it sit and idle it will take about 45 seconds and it will idle down to 1000
my friends cars the same just an auto and he starts his and it idles great even on cold starts
might be related but when i park my car after driving it kinda smells like gas as i get out, but not when sittin there...think the charcoal canister might be full...can you dry it out or clean it out or do you have to purchase a new one?
car also idles rough somtimes...bounces from 800-1000 like it spudders...
mods are longtubes k and n cold air...tr6 (might cause rough idle???) poly motor and trans mounts...bmr subframes...lca/relos thats it....nothin on the motor tranny or car is older than 9k miles...
also notice someimtes that my car slowing down to a stoplight in neutral it will idle from 1200-1500 surging slowly...which i dont think is normal...any ideas?
Old Oct 29, 2007 | 02:05 PM
the_merv's Avatar
Is this the LS1..
Old Oct 29, 2007 | 02:35 PM
LOUDandPROUD96's Avatar
i had a similar problem and i smelled raw fuel when the car was off. I replaced my fuel pressure regulator and the problem was solved.
Old Oct 29, 2007 | 03:47 PM
daniel6718's Avatar
nope friggin dd lt1...
got your car to the track yet?
mines got no fuel leaks...it had a bad pump i replaced it and car ran 100 times better...fuel pressue before was 25 at its highest point...now its rock hard at 48-50 all the time....
also forgot to mention this car hard starts...im thinking that something is going tofix most of not all this in one shot just not sure what is it....
guess pull the plugs first and check it out..any ideas?
Old Oct 29, 2007 | 05:53 PM
the_merv's Avatar
Could be the Ignition..sounds like when it goes into Closed Loop it levels out, may possibly be related to that..
I'm actually putting the Engine back in it here this weekend..Oil Pump went out in the setup and spun a Rod Bearing..got very lucky with it, there was very minor damage to it. About $500 to put it back on the Road.
Old Oct 29, 2007 | 07:31 PM
jasonp31's Avatar
Symptoms sound like a vac leak to me. Do you happen to have a vac gauge?
Old Oct 29, 2007 | 07:41 PM
daniel6718's Avatar
no vac gauge...thats what i though was a vac leak...but im not sure where...originally it idles high all the time then i found the pcv vale has a rubber piece from it to the metal line to the front of the intake and it was cracked by where the metal line meets the rubber line under the t/bfixed that and it was 100% better...but now im not sure where else it could be...i might need to check that i didnt mess anything up there...
btw the car has no egr or air...
Old Oct 31, 2007 | 11:47 AM
daniel6718's Avatar
checked vacume and its 18-20 at idle...normal?
Old Oct 31, 2007 | 01:30 PM
the_merv's Avatar
That's normal.
Old Oct 31, 2007 | 01:32 PM
ckyconan2003's Avatar
merv, where do you run the car at? where is jacksonville? how far from Arkadelphia? Your IAC working right?
Old Oct 31, 2007 | 01:34 PM
the_merv's Avatar
Jacksonville is about 1.5 hours from Arkadelphia..just above Little Rock. What's up?
Yea, it could be his IAC...
Old Oct 31, 2007 | 01:37 PM
daniel6718's Avatar
what is the iac counts supposed to be at idle on a completely stock lt1?
Old Oct 31, 2007 | 02:20 PM
I8ASaleen's Avatar
Sounds like a fuel issue if you are smelling gas. Check all ur lines and then go to the FPR and fuel filter.
Old Oct 31, 2007 | 02:27 PM
FAD2BLK93's Avatar
I would check the IAC counts...in the 20-40 range.
Old Oct 31, 2007 | 04:39 PM
daniel6718's Avatar
i dont think its fuel issue...pretty sure the charcoal canister is close to being full
no leaks as i been tracing down a fuel pressure drop after i turn off the pump...i just installed it...it actually made a bunch of the problems go away i had 25 psi before it...but i have a guage and its rock hard at 46 psi or so at idle
im goana try to check the iac counts this weekend ill keep yall updated
yall sure that 18-20 of vacume is right?
Old Oct 31, 2007 | 09:18 PM
the_merv's Avatar
Yea..18-20 is stock. Mine was steady at 17 with the Hotcam.
Old Nov 10, 2007 | 06:16 PM
daniel6718's Avatar
iac was around 29 at idle...never went below 25 or above 35...perfectly normal...
o2 were both boucing around like normal...neither was lazy...blm i think were around 120....
weird though the desired idle was 800..but on the scanner it said it was idleing between 920-960
Old Nov 10, 2007 | 07:38 PM
Ralls's Avatar
FYI, as soon as liquid gas gets in the charcoal canister, it's ruined. If your suspecting it's the EVAP system, pull the EVAP lines off and see if they have raw fuel in them. Better yet, go ahead and disconnect it from the motor to see if it's the problem. All you have to do is disconnect the purge solenoid connector and plug off the throttle body port.
And how old is the fuel filter?
Old Nov 10, 2007 | 08:44 PM
daniel6718's Avatar
already pulled the line and blocked it off...didnt fix it...
also i replaced the filter about 2k ago
Old Nov 11, 2007 | 01:46 AM
GMRACER13's Avatar
Since you have a scanner look at your coolant temp. sensor. It's the one in the water pump not the one in the driver's side head (that's for the gauge) If it has failed and the computer thinks the engine is dead cold it will dump a whole lot of fuel and can cause the fuel smell and hard starting. Just an idea.
