When the car is cold....
Old 10-31-2007, 03:59 PM
Ironxcross's Avatar
Default When the car is cold....
For some reason, when the car is cold, the oil pressure gauges goes to like 40-50 and stays there until it warms up then it drops to 10-20 or so. And the other thing it does is that the throttle sticks a little, it likes to hold a 1500-2000 rpm idle when the car is moving (while in neutral) but if i stop it goes down to the usual 1000. does anyone know why these things happen other than the fact its a 10 year old car?
Old 10-31-2007, 05:14 PM
Rowdy94's Avatar
I don't see the problem with the first "problem" you mentioned, other than 10 psi is pretty low. Your oil pressure is always lower once the motor warms up.
Old 10-31-2007, 05:23 PM
rudeLT1's Avatar
it has a higher idle when cold to warm the motor faster, instead of 1k like usual its up around 1200-1500, nothin to be alarmed about. the oil pressure is due to the same thing. mine does this and im sure everyone elses does to, nothing to worry about
correct me if im wrong guys....
Old 10-31-2007, 05:25 PM
94BlackSSClone's Avatar
naw, you're perfectly right
Old 10-31-2007, 05:27 PM
transamws6_97's Avatar
also while moving your idle should be a little higher but not 2k
Old 10-31-2007, 05:56 PM
Ironxcross's Avatar
its not always 2k, but it sometimes goes that high, but if i stop, it goes to 1k
Old 10-31-2007, 06:21 PM
GreenBlood's Avatar
my car does the same thing...cold startup, idles at about 1100 RPMs and runs just over 40 psi, once warm, it idles at about 600-650, and the pressure drops to about 16-20 psi or higher under throttle though...i limit my cold start driving though because I have a remote start, so my car is usually running for about 5-10 minutes before i drive it in the cold...
Old 10-31-2007, 08:06 PM
Ironxcross's Avatar
so 1k idle is a bit high?
Old 10-31-2007, 08:11 PM
GreenBlood's Avatar
for a stock car and warmed up? just a little high i think...my old B4C never idled higher than 800, and my current formula is at about 600-700 when warmed up...
Old 10-31-2007, 08:21 PM
letsrun97z's Avatar
stock tac is off my says 1k but on the scanner its 825
Old 10-31-2007, 08:22 PM
Ironxcross's Avatar
ahh ok
Old 10-31-2007, 08:33 PM
transam5.7lt1's Avatar
Looks like its normal, your oil pressure seems kind of low to me but as long as it raises when given accleration you should be fine. Worry about when it won't go up with some throttle.
Old 10-31-2007, 09:32 PM
Ironxcross's Avatar
yeah, it goes up to about the middle of the gauge when at or around 2k
Old 10-31-2007, 09:53 PM
Biggin'89's Avatar
dont worry about the start-up pressure, i would be a lil more concerned about being as low as 10psi tho.
and while moving it does generally stay about 1500-1700 b/c of the speed sensor and how its programmed, the other guy was an a4 so his idles are different than our m6's. so don't worry about that either.
Old 10-31-2007, 10:38 PM
Ironxcross's Avatar
im sorry, my oil psi at idle when the car is warm is at 20, and its around 40 at 2k
Old 11-01-2007, 12:18 AM
well i just had to replace my oil pressure sending unit cuz my last one was broke but I have 70 psi cold startup and i never even touch 40 psi at full temp. Always above it no matter what. Not to shabby for an old lt1 w/ 145k
Quick Reply: When the car is cold....
