Recommendation On Piston Rings
Old 11-06-2007, 04:11 PM
FASTFATBOY's Avatar
Default Recommendation On Piston Rings
I had to pull mine back down, it hurt two pistons on the chassis dyno due to bad gas. That is bad news, the good news is it ran 11.20@120 and made 463 rwhp with two hurt pistons
I have Hellfire rings in it now and plan on spraying a 200/250 shot later on.
But have been told the Hellfire is hard on cylinder walls for a street driven car.
Any suggestions on a ring for this car?
David
Old 11-06-2007, 05:37 PM
flyinZ's Avatar
Total Seal
Old 11-06-2007, 05:39 PM
FASTFATBOY's Avatar
Originally Posted by flyinZ
Total Seal
Total Seal? WHat kind? A zero gap? Cant really use that with spray huh?
David
Old 11-06-2007, 05:50 PM
97badass's Avatar
total seal is a brand of rings...if thats what your asking
Old 11-06-2007, 06:20 PM
FASTFATBOY's Avatar
Well, I kinda knew that......Total seal probably makes 50 different "kinds" of rings. A gapless top, gapless second or conventional rings All kinds.
David
Old 11-06-2007, 07:01 PM
cnorton's Avatar
Call Total Seal, ask for Keith Jones. He'll ask you a dozen questions about your set-up, your goals, and how you use the car. Then, he'll set you up with the right stuff. I had not used their stuff until about the past three years. Total Seal has their stuff together!
Old 11-07-2007, 07:09 PM
flyinZ's Avatar
Gapless, maybe something like File-fit rings?
