Blocking EGR
Old Nov 10, 2007 | 07:31 PM
My94TransAm's Avatar
Default Blocking EGR
Can I block off the pipe coming off the rear passenger header and the intake without throwing a code. The pipe is broke causing a major exhuast leak, and I would assume warm air going into the intake would hurt performance. So I figure the best thing to do is block it off. Oh and it is an OBD1 car.
Old Nov 10, 2007 | 07:48 PM
Ralls's Avatar
Yes, it will throw a code once it sees the EGR isn't working. You might as well remove the EGR system unless you plan on fixing the header.
Oh and, the exhaust gas is actually cool in comparison to combustion chamber temperatures.
Old Nov 10, 2007 | 08:26 PM
Razor_Blade's Avatar
No, it won't throw a code as long as the egr solenoid remains plugged in. Just unhook the vacum hose that goes to the solenoid and leave the electrical plug in place. You can then remove and block the pipe and the egr valve. I'm sure someone will be along shortly to explain how this won't work, but my car has been running like that for almost a year without any codes.
Old Nov 11, 2007 | 10:01 AM
Thanks guys, anyone else have any input?
Old Nov 11, 2007 | 01:32 PM
DBEST369's Avatar
i just blocked it on my v6 a year ago n no codes, and im actually thinkin bout doing it to my trans am right now haha
Old Nov 11, 2007 | 06:50 PM
Does anyone makes the block off plates? If so who? I need them asap cause I am about to go crazy with this leak.
Old Nov 11, 2007 | 07:02 PM
Ralls's Avatar
Just go to Home Depot and spend a few dollars on a piece of sheet metal and cut out your own. Then use RTV as the gasket.
Old Nov 11, 2007 | 11:07 PM
formulakid1's Avatar
That's exactly what I was thinking.
I installed a set of block off plates for a guy. He had bought them from some store.....and I know I could of made a better looking piece with a cut off wheel and a grinder!
Old Nov 12, 2007 | 02:11 PM
hyperzone's Avatar
UMI makes a set of block off plates.
Old Nov 14, 2007 | 01:32 AM
DBEST369's Avatar
my service engine came on today
