help
Old Nov 27, 2007 | 09:47 AM
wht-z's Avatar
Default help
i just intalled a newly rebuilt lt1 in my 95 z28, we went to start it all it will do is turn over will not start. we checked fuel pressure, fuses, took front cover off to check that all was lined up right, then we checked the spark by taking #1 plug out to see if there is spark there was but when grounding out the plug the engine actually fired up for a split second. we are going to try it once more to see if it will do it again. any thoughts on this?
Old Nov 27, 2007 | 10:25 AM
dhdenney's Avatar
Is it 180 out? Is it "hiccuping" while you are cranking it?
Old Nov 27, 2007 | 10:32 AM
Formula96's Avatar
^^ I agree with him, sounds like it is 180 degrees out.
Old Nov 27, 2007 | 10:37 AM
Red96TA's Avatar
I thought LT1's couldnt be 180 out because the opti only goes on one way?
Old Nov 27, 2007 | 10:38 AM
wht-z's Avatar
no it did not do anything but turn over, it should not be 180 out we had the timing dots lined up at 6 and 12 with the cam dowel at 3 which puts #6 tdc then we rotated the engine to 12 and 12 and the cam dowel at 9 which puts #1 tdc and checked to make sure by pulling the plug and checking, then we put the opti on with indicator on it pointing at #1
Old Nov 27, 2007 | 10:55 AM
Red96TA's Avatar
Your opti should only go on one way...make sure its lined up. Theres a key on the spline that lines up take a look and make sure its on the right way.
wht-z's Avatar
where did everyone go? i am right with what i did as far as the timing is concered right?
Old Nov 27, 2007 | 11:31 AM
wht-z's Avatar
are there any other opinions
Old Nov 27, 2007 | 12:59 PM
dhdenney's Avatar
That sounds right. Like was said, maybe you missed a spline or two when inserting the opti drive shaft. Additionally, pull your driver side valve cover to double check which valve is open when timing the opti. I know you said you checked fuses, but did you check them all? Also you said fuel pressure was good, I presume you checked it at the rail?
Old Nov 27, 2007 | 02:21 PM
wht-z's Avatar
what splines are you talking about?
Old Nov 27, 2007 | 11:09 PM
dhdenney's Avatar
On the little opti driveshaft.
Old Nov 28, 2007 | 08:31 AM
wht-z's Avatar
isnt there only one way that it will go on?
Old Nov 28, 2007 | 09:33 AM
dhdenney's Avatar
Yes and no. You do have the older unvented opti correct? There's a little key on both sides of the drive which you have to put correctly into the slot on the opti and inside the cam gear. It has been reported that some have inserted it wrong. Also, make double sure the slot is in fact at the 9:00 position. I have had problems in the past with that and turns out it was the angle I was looking at the slot and it was not in the right position--more like 10:00. I made a point to crawl under the car and stick my face right on the timing cover to verify position. Additionally I have used a screwdriver to verify TDC on #1 by feeling for the top of the piston.
Old Nov 28, 2007 | 10:13 AM
wht-z's Avatar
no it is the vented style, but now i have another question, is it possible for the opti drive shaft to come out. because i wondering if it is even on the back of the opti. i dont remember
Old Nov 28, 2007 | 10:54 AM
Red96TA's Avatar
Why does it have to be at 9 oclock? If it only goes on properly one way it shouldnt matter what position the spline is in when the opti goes on... maybe this is whats giving me problems...
Old Nov 28, 2007 | 11:15 AM
dhdenney's Avatar
OK I have no experience with the vented style so I am not so sure.
Old Nov 28, 2007 | 11:16 AM
dhdenney's Avatar
It's not so much the position of the opti but the position of the engine.
Old Nov 28, 2007 | 12:22 PM
wht-z's Avatar
does anyone else know anything about the vented optis?
